How to set the fuel screw.
Old May 1, 2008 | 06:48 AM
WestOzKLX's Avatar
Default How to set the fuel screw.
Has anyone got the info' that was post on how to set the fuel screw. I tried the search function but came up empty.
It gave info on tuning the screw, turning it out, turning it in and the ideal setting. [sm=feedback.gif]
Old May 1, 2008 | 07:45 AM
WestOzKLX's Avatar
Default RE: How to set the fuel screw.
Found this link, it answers all of my questions.
http://cbreysse.club.fr/profgromono/...LX250R300R.pdf
[sm=closed.gif][sm=closed.gif]
Old May 1, 2008 | 09:50 AM
didnt read that pdf.... but i thaught to correctly set the screw the bike needs to be running, and to adjust the screw with it running you need that 90degree screw driver or kouba fuel screw.
Old May 1, 2008 | 09:54 AM
WestOzKLX's Avatar
Yup. I've got a Kouba screw.
Old May 3, 2008 | 09:27 PM
djmerullo's Avatar
Can U send mea link to get one of those fuel screws and let me know how to install? Thanks, Dave.
ORIGINAL: WestOzKLX
Old May 4, 2008 | 01:04 AM
pie4foou's Avatar
i'm pretty sure if you have the bike running and you turn the screw one way till the bike runs like crap and then turn it back the other way while counting how many turns, untill it runs like crap again, then set it to half what you counted.... thats what my mechanic said, but who knows for sure how accurate that is...
Old May 4, 2008 | 01:13 AM
WestOzKLX's Avatar
http://koubalink.com/fuelscrew.html
Install like this.
Just follow the instructions on the link below. This will have your carb' out and access to the OE fuel screw.
http://hmfengineering.com/forums/showthread.php?t=1617
Old May 4, 2008 | 04:00 PM
djmerullo's Avatar
Hey bro in the middle of the carb bowl do u have a cutin it? Mine started to leak the other day I have looked all over to find a new one with no avail. does anyone know where to get a bowl for a keihin cvk34? if so I would love to purchase one. also do you have to take the little cap off the set screw?
ORIGINAL: WestOzKLX
Install like this.
Old May 4, 2008 | 04:06 PM
djmerullo's Avatar
Thanks west for that wonderful site. Couldnt U instead of taking all that stuff off just take the seat off remove the fuel hoses followed by the tps push pull cables, then take the flanges on the carb loose then pull it out the hole where the air box was?
ORIGINAL: WestOzKLX
Install like this.
Old May 4, 2008 | 06:10 PM
WestOzKLX's Avatar
We've got the 300cc high flow airboot on our AUS spec bikes down here. They're flexible rubber not the hard plastic you get. I've never taken it off, so I wouldn't know if it's easier? I can have the carb' out in about 10 minutes now as I've done it a few times. The 300 airboot does make it easier than you guys with the hard plastic square boot. Oh, and we dont have TPS or the "smog" stuff on AUS spec bikes either. Our bikes are actually KLX250R models, you guys get KLX250S. My log book says KLX250R H7. I'm sure that's why we get a few different parts to the USA spec bikes.
