Hotter Thermostat
Old Sep 23, 2019 | 05:22 PM
oldgypsy's Avatar
Default Hotter Thermostat
As I understand it, the Thermobob kit comes with a hotter thermostat. Will that thermostat fit as a direct replacement for the OEM thermostat? And if so, who makes it and what is that manufacturer's part number?
Old Sep 24, 2019 | 11:06 AM
klxnoobie's Avatar
Old Sep 27, 2019 | 03:25 PM
Haldor's Avatar
On my KLR650, the Thermobob uses a smaller diameter thermostat than the OEM. The KLX250 housing looks very similar to the KLR650's, so I expect it will be the same.
The Thermobob is more than just a hotter thermostat. It also provides a bypass loop so you always have some coolant flowing through the engine even with the the thermostat closed. With the OEM configuration, the thermostat shuts off coolant flow completely when closed.
That is how the Thermobob is able to reduce the wild temperature swings the OEM coolent system subjects the engine to during warm-up.
Here is a link to the spare thermostat if you want to try ordering it by itself. But it won't fit your bike without the rest of the Thermobob.
https://shop.watt-man.com/Thermo-Bob...-O-ring-S2.htm
Old Sep 27, 2019 | 03:44 PM
Take the thermostat to an automotive parts store and match it up.
The KLX has an interesting alternative to the thermo bob - as I learned after doing the thermo bob. Seems there is a port to the back side of the thermostat at the rear of the cylinder. If you put an in-line fitting in the correct radiator tube and a fitting in the cylinder head, connecting them with a hose, it now has a bypass.
Posted here click
And here click
And here is the install click
The install shows which hose to cut for the fitting.
Old Sep 27, 2019 | 04:32 PM
oldgypsy's Avatar
Mark,
Thanks for posting the links to the Thermobob "look-alike". It will be helpful to those who want to essentially duplicate the Thermobob, but at a much lower cost. I've done it already and it is quite easy to do. Thanks also for confirming that the Thermobob housing is dimensionally different from the OEM housing.
Old Sep 28, 2019 | 01:45 AM
Couldn't remember who did it, but ingenious, finding a low buck solution for more uniform cylinder temp.
Old Sep 28, 2019 | 05:40 PM
oldgypsy's Avatar
MrCrisper
407guy
Oct 10, 2023 01:42 AM
snowwolf
KLR650
Mar 25, 2016 08:09 PM
alexgg
Oct 1, 2013 12:53 AM
dacoontz
Nov 24, 2010 12:40 AM
intense_05_636
Feb 11, 2009 03:49 PM
