Honda crf250L.....
I guess its human nature to want what the other guy have. FI is good but I have read some guys with FI bikes wish they have the carb instead. To each his own lol. Me personally, before I wish my klx has FI but after it has been rejetted and it runs no problems from 3t to around 10t feet elevation with no problems, I'm happy with what I have. Less expensive to get more power. Easier to fix on the trail .
To a bike that actually runs out of the box and doesn't require choke enrichment drilling, re jetting, opening the air-box, after-market exhaust, etc........Just to make it idle and run properly and doesn't stumble all over itself.
The Honda is considerably cheaper considering what you need to add to the Kawasaki just to make it do what it should do from the start....start and run without stumbling all over the place.
Your essentially stuck with the stock pipe as well on the honda, unless you want to pony up the 3 bills or more for a power commander, which turns a $500 exhaust into a $800+ exhaust.
Yea, I'll take the FI any day of the week.
I can fire up my Goldwing and fly down the road instantly without one single hesitation or grumble.............ride the highest mountains or the lowest valleys without any performance degradation or MPG changes.
I'm not hating on FI, i just haven't seen firsthand what all the fuss is about. My carbs work, FI works, but niether seem to work better than one or the other that i have seen. One is much more complicated and expensive to work on though.
btw - Mr. Disney was a genius........I could only wish he was around to design a bike.
Yeah such a genius that his company that made billions off of works that were in the public domain and then his greedy company got the copyright protection extended for like another 140 years so none of THEIR work would lapse into the public domain.
Guess i should just have beef with the company rather than the man though.I'm not trying to start a fight or get any bad blood going on around here, i'm just stating my (slighty strong
) opinion based on my own experiences.
Guess i should just have beef with the company rather than the man though.I fully concur that Disney the company is utterly di****able. As for Disney the man, I wonder what he would have thought...
On the motorcycle FI, aren't most of them, and especially dirt bikes, a throttle body FI instead of direct injection like most cars? I think all of the TB models would operate much better with a direct injector. Throttle body works pretty darned well, but there's a reason most all cars have gone to DI.
Also most FI bikes operate on a speed density type of management system which is VERY limited in fuel adjustment other than in a very narrow set of operational parameters, fine if you keep the bike all stock but new exhaust or intake mods can seriously affect fueling.
I do wonder about the goldwing though, i wouldn't be at all surprised to see a full on direct injection setup on those, its not like they don't have the room... lol
Most cars have port fuel injection, direct injection is a whole other animal that is starting to become more prevalent. It allows higher compression ratios while retaining lower combustion temperatures and lower emissions. A bike with direct injection would be pretty bad ***, it would be loud though because the injectors tend to rattle.
No bad blood........we're all opinionated to some extent.
Just don't dis good 'ole Walt.
I'm sure he'd turn over in his grave if he knew some of the modern Walt Disney corporate tactics.
I disagree..........a lot of other manufacturers/models have the same EPA guidelines and their bikes don't suffer from the same ride-ability issues.
