Hitch Mounted Carriers
Did a search and saw where several KLX owners have or have used the hitch mounted carriers.
My question is that I have a Jeep Wrangler Unlimited (4-door) running 286/65 33's tires and it's lifted 2 1/2 inches. Is this going to make it difficult getting the bike off and on for one person? The video clips that I've seen from manufacturers show most vehicles being a standard height. I'm also guessing that I'm going to have to take the spare tire off the back in order to use the hitch carrier.
Any thoughts?
By the way, I'm a new KLX owner with 103 miles so far. It's been cold as snot here in Atlanta the last week or so and riding has been difficult at best. I did manage to go out for a nice ride today......
Any thoughts?
It shouldn't be a problem with one person, though you may need some momentum or engine power (as stated above). I find with hitch racks I have much more trouble getting the bike off than on, since it settles into the gaps in the rack (for certain rack types, anyways).
Also, if you have a full size spare it may hit, but I'm surprised how far out from the hitch my rack sticks. You may clear it.
How sturdy are these on dirt roads? do the bikes flop around much?
Im over towing a trailer everywhere.
Cheers
Paul
________
Essential vaaapp
Cheers
Paul
________
Essential vaaapp
My bike is very securely mounted to the rack, but the rack definitely moves around in the hitch a bit. I'd recommend a stabilizer/anti rattle device or whatever you want to call it, though I don't have one myself. My rack has survived hundreds of miles of mountain roads (mostly paved though), and a decent amount of washboard roads. Make sure you have decent springs in the rear of your vehicle though, otherwise your handling can be scary at speed.
Any thoughts?
Any thoughts?
I promptly tied it down and made my next stop a friends house that is a welder by trade to discuss possible modification. We came up with a great solution of not modifying the actual carrier but building a whole unit that slides into the truck reciever, drops down about ten inches to another reciever tube that the carrier now slides into. The new reciever tube has four bolts that I tighten down to prevent the carrier from swaying. It works great and the bike carrier can still be used on a stock height vehicle. Just an idea that worked for me. . .
Have a amc-400 carrier and can roll my dirtbike on pretty ez, the klx I would walk it up with power. It came with the gizmo that keep it from rocking in the receiver, it works and has never loosened up. I did need to grind on it a bit to sit flush against my style receiver tube, no biggie. I wouldn't trust those cheap tie downs they supply for this application, thin Chinese junk. Because of the sling angle you want some better quality 1 " tie down secured with a knot (had them slip) or some good 1.5" tie down.
No actual picture of the rack on my car, but here is the rack:
http://www2.northerntool.com/trailer...tem-125910.htm
When you say use the motor to load, are you walking it up the ramp in first or riding it up?
Also, now I'm looking at the Ultimate MXHauler, same concept but different engineering. Would definitely solve loading issues but cost more......
http://www.ultimatemxhauler.com
