help posting signature on this forum
Old May 10, 2020 | 08:16 PM
ekim250's Avatar
Default help posting signature on this forum
I'm having trouble posting my signature. I keep getting this message even though it's only about really short.
Your signature contains too many lines and must be shortened. You may only have up to 5 line(s). Long text may have been implicitly wrapped, causing it to be counted as multiple lines.
Old May 10, 2020 | 08:42 PM
BigBadLou's Avatar
I see this in your signature:
2009 KLX250SF K158 main #35 pilot DJ needle 1N Kouba screw 4 turns out Sea Level
Is that the desired one?
If not, feel free to post the one you want here and I'll take a look if I can make it work.
Old May 10, 2020 | 08:47 PM
ekim250's Avatar
2009 KLX250SF K158 main #35 pilot DJ needle 1N Kouba screw 2 turns out Sea Level Lidless Full Muzzy
Thank You!
Old May 10, 2020 | 09:26 PM
BigBadLou's Avatar
Let me try, I copied and pasted your desired signature into my signature editor and saved it. Did not receive any errors.
Previe showed the whole line of text.
Let me post this reply to see how it comes out for real.
Old May 10, 2020 | 09:27 PM
BigBadLou's Avatar
Well, that worked.
That is what you want to show under your posts, correct?
Checking that the signature is gone now.
Old May 10, 2020 | 09:29 PM
BigBadLou's Avatar
I would try a different browser first. I would also try to delete the signature, save the changes and then add it again from scratch.
If you still have trouble, You would need to contact an admin since I am not one, I am just a user trying to help. Something might be wrong in your account settings and admins should be able to rectify that.
Old May 10, 2020 | 11:04 PM
ekim250's Avatar
No luck. I'll keep trying. Admins might help.
Old May 11, 2020 | 12:11 AM
AussieCheech's Avatar
I had that as well. Go back in to update your signature and you may find that under your line of text, you have a bunch of returns. So it looks like you have only 1 line, but you have more lines just with no test in them.
Old May 11, 2020 | 12:21 AM
ekim250's Avatar
That did the trick. Thanks mate!
grandpawj
Dec 20, 2016 05:21 PM
Landon
Jun 25, 2013 11:52 PM
wildcard
Apr 30, 2012 11:52 PM
baldie
Aug 4, 2009 08:09 AM
afboundguy
Jul 1, 2007 05:39 AM
