HELP!!!!!!!!!!!PLEASE!!!!!!!!
Old Aug 20, 2007 | 08:31 PM
r8d8ter's Avatar
Default HELP!!!!!!!!!!!PLEASE!!!!!!!!
Hey all, im trying to install the bill blue bumper carb special and.......yes.....im having trouble attaching the throttle cables to the carb, I know, I know, its probably easy to figure out but Im having trouble. Im not sure how you do it. I guess bill forgot to email me the installation instructions. If anyone has a pic or a copy of the install instructions I would appreciate it.
thanks
steve
Old Aug 20, 2007 | 09:23 PM
KLXer's Avatar
Default RE: HELP!!!!!!!!!!!PLEASE!!!!!!!!
Put the barralls on the wheel first, then adjust/tighten the nuts.
Old Aug 20, 2007 | 09:49 PM
r8d8ter's Avatar
Hey KLXer thanks for the response, I assume the bent throttle cable (silver elbow cable) goes on the front wheel right? and the straight one goes on the back wheel?
Old Aug 20, 2007 | 09:57 PM
KLXer's Avatar
Yes sounds right.
Old Aug 21, 2007 | 03:10 AM
johnnyz62's Avatar
Steve, Below is a write up that I did on the install this spring. I'll also attach some pics that might help. I only used the pull cable as I don't think that the intention is to use the push cable for this application. Good luck and by the time you get the jetting done you will probably be an expert.
I was lucky as it ran well out of the box. Bill tested on his bike, it worked on hisand we are at the same elevation . If you haven't already pulled the smog stuff, now is the time. There is not a place to plug the vacuum hose into the new carb. I would also remove the ground wire from the battery just to be on the safe side. You will be working right above the starter and sparks are bad when doing carb work.
1. Remove plastics, seat, and tank. Remove the petcock bolts and it will pull out with the tank. Be sure to turn the gas off before removing the gas line. Get new screw clamps for the carb and petcock ahead of time toeliminate crappy stock clamps. Keep an eye on the fuel tank vent hose routing. I'd suggest taking some pictures before taking things apart to aid in re-assembly.
2.Take apartthrottle assembly at handlebars (two screws, white cable guide, and housing). The cable toward the front of the bike is the push cable and will not be needed with the new carb. You can either plug the empty hole with RTV or a set screw of the same size with some loctite. Remove push cable from bike.
3. Follow throttle position sensor wire from carb back up to the connector up by the frame. There is a latch that will need pushed in to separate the two halves of the connector. Once the latch is pushed in far enough it will come apart fairly easily. I'm doing this from memory but think you will need to cut a couple wire ties to get the wire harness out of the way. You will also need to move the wire harness out of the little frame bracket to make room to get the carb out.
4. Loosen clamps on air boot from the air box and where carb connects to the motor. Loosen the throttle cables at the carb and remove cable mounting bracket. I found it easier to pull the carb away from the motor first then pull the boot off. Loosen the clamp on the air boot enough to slide the clamp back out of the way. Pull carb straight up through the frame (may seem more like a jigsaw puzzle at this point). Also if using my method, tip carb in such a direction to let the gas flow freely through the vent hose, down your pant leg and all over the garage floor. Not a good time for a smoke break.
5. Remove throttle cable bracket from new carb.
6. Lube air boot and inlet to engine with lite coat of wd-40 to aid in assembly.
7. Remove little wire bracket that holds the idle adjuster as it will be re-mounted under the rear brake fluid resevoir bolt. Let it hang for now but keep an eye on it as well as the vent lines since they will end up somewhere in the way, just because they can. Malcom's Law, Murphy invented it but I perfected it.
8. Slide carb inlet into air boot then push it back to get the carb outlet into motor. It may be a good idea to reattach the throttle cable to the carb at this point to check for clearance during throttle movement. On mine there is a tab on the carb throttle mechanism that hit the frame. Test for clearance by pulling the cable up by the handlebars. If it hits the frame, turn the top of the carb to the right side of bike to create clearance.
9. Install idle adjuster hanger under rear brake fluid reservoir bolt.
10. Install throttle cable bracket, throttle cable and throttle assembly. I think 1/4 inch of free play is called out for as an adjustment but I prefer less play. I keep it just loose enough to not effect engine idle RPM.
11. Drop gas tank into place. You will need to put a little twist in the gas line since the fuel inlet is in a different location on the new carb (put new clamps on line first). Re-attach petcock to bracket.
12. Secure wire harness to original locations with new wire ties.
13. Turn on fuel and check for leaks.
14. Reattach ground wire to battery.
15. Twist throttle three times and try to start. If it doesn't start right away pull the choke out and try again.
16.After it starts, let it warm up for a short time and push in choke. Will probably need to adjust idle at this point.
17. Let the bike warm up good then adjust air fuel mixture.
18. Reinstall seat and plastics.
Old Aug 21, 2007 | 07:21 AM
MaverickAus's Avatar
nice write up
Old Aug 21, 2007 | 10:42 AM
r8d8ter's Avatar
Johnny,
Nice details, thank you for your time in putting that together. The two trottle cables were throwing me off, now i realize im only to use one of them. Knowing that makes the install a WHOLE LOT easier.
Thanks again
steve
Ninjaattack
Mar 23, 2010 04:44 AM
WestOzKLX
Apr 21, 2008 07:23 PM
fredhill032188
Jul 24, 2007 10:47 PM
STANGRACER85
Apr 25, 2006 04:37 PM
