Help jetting 8000+ elevation
Edit: In fact that collar may be the actual needle jet orifice, but I thought it was a harder alloy to keep from wearing too quickly. And if my reading comprehension was correct that I just did, it may be designed to fit one way back into the carb. Here's a link that "might" help.
http://myural.com/keihin_32cvk_disassembly.htm
Brewster, aren't we talking about that alloy collar goes in from the bottom of the carb above the holder that screws into the carb bottom and accepts the main jet?.
Keihin 32CVK Disassembly
Your edit is correct, you are thinking about the needle jet.
Ride on
Brewster
Some people seem to call the silver looking "collar" above the main jet holder a "needle jet" anyway I ordered both collar and needle jet because of this confusion. I feel I'm so close. Couldn't put myself through ordering the wrong part.
I think you're on the right track. Without that collar/needle jet part, you'll get some weird results. The needle jet in most Mikuni's is just a one-piece affair that assists in metering fuel flow from the main jet and around the needle. It looks like all Keihin CVK's may use this collar/needle jet system. I think the terminology used in these parts diagrams is a bit confusing. It appears to me that the collar is the needle jet, but if that's the case, how do you select a different needle jet for tuning? And there may indeed be different "collars" for that purpose that I just haven't noticed before. It looks like what I'd normally call a needle jet in a Mikuni may just be a holder and emulsion tube for the main jet and needle jet (collar) in this CVK carb. I'm sure I could do more research, but I'm not using the CVK carb anymore.
finally got my order
16009-1912--------Needle-Jet,N1TC
92143-1667--------Needle Collar (required for N1TC needle)
92037-1401--------Clamp, Needle Jet (Clip, required for N1TC needle)
none of these are the part i am looking for..... another 30 bucks down the drain and no answer...
how can i find this part?
ordered
16017: JET-NEEDLE part# 780630 bikebandit.com
needed the JET-NEEDLE not the NEEDLE-JET, and not the COLLAR of course i love how ****ing clear and strait forward all this is. Really wish i had known about
2009 Kawasaki KLX250SF KLX250W Parts, 2009 Kawasaki KLX250SF KLX250W OEM Parts - BikeBandit.com
shows a diagram of all the parts in the carb... would have made it easier.
but i didn't... so I'm still dealing with the hell i have unknowingly brought upon myself.
I feel your pain brother...
https://www.kawasakiforums.com/forum...ibungle-40218/
...but it will be worth it once you eventually get things sorted.
