Help with Acerbis...Please?
Old 10-12-2007, 02:28 PM
fireroad's Avatar
Default Help with Acerbis...Please?
Can someone who has mounted the Acerbis rally pro's post a pic of where they routed the cables, especially the clutch cable? I've tried over, under, around and through and can't seem to make it work without binding/sticking? I'm mounting them on tusk handlebars?
Old 10-12-2007, 08:00 PM
stellar_d's Avatar
Default RE: Help with Acerbis...Please?
Heres a couple pics of mine, hope it shows what you need. stocker bars though
Old 10-12-2007, 11:43 PM
fireroad's Avatar
thanks derrick, do you have any close-ups of (the inside or bird'd eye view) of the side where it attaches with the bracket (opposite of bar end)? It seems like everywhere I try to put them they interfer with the function of something.
Old 10-13-2007, 12:42 AM
2k1w=no$'s Avatar
Fireroad I will look tommorow, I have the rally pro handguards and yes it was tricky to get the cables right. I do know that on the brake level side I took a hole saw and cut clearance for the brake line. I also ran a shorty clutch lever and cut 3/4 inch off the brake lever and welded the ball back on. I will look for the cable routing tommorow.
Old 10-13-2007, 02:15 AM
mudjunkie's Avatar
Here's a pic of what you may have to do around the brake cable.....the rest seemed to go pretty smooth (once the counterweights were removed from the bar ends of course)
Old 10-16-2007, 12:51 AM
2k1w=no$'s Avatar
Old 10-16-2007, 12:55 AM
2k1w=no$'s Avatar
Old 10-16-2007, 12:58 AM
2k1w=no$'s Avatar
Old 10-16-2007, 01:01 AM
2k1w=no$'s Avatar
Old 10-16-2007, 01:08 AM
2k1w=no$'s Avatar
Sorry for the attachments, will try the photobucket thing next time. Note that my brake line is in front of the throttle cables where stellar-d has his line behind the cables. It seems to have more free movement when it is in front. Also in the pitcure where the hand guard is cut out for the brake ine there is a small chunk of plastic missing on top where it was lost in a spill. Hope the pics help.
Quick Reply: Help with Acerbis...Please?
