Help
Old Aug 22, 2009 | 06:00 PM
winter737's Avatar
Default Help
Pulled the snorkel off my new 250S now seems to be weak in the low end, is there anything else I need to do right away?
Old Aug 22, 2009 | 06:20 PM
bonekrusher's Avatar
I'm no expert on that but from what I've read you want to rejet since you are allowing more air you may be running lean. It would depend on your altitude as well.
Old Aug 22, 2009 | 06:44 PM
winter737's Avatar
Exactly what I was thinking, thanks!
Old Aug 22, 2009 | 07:05 PM
winter737's Avatar
Dyno main 128 or 132, suggestions..... live at about 700 feet ride anywhere from 2000-7000
Old Aug 22, 2009 | 10:01 PM
Xplosivo1's Avatar
Go with the bigger one and get the kouba fuel Adjustment screw. Better to run rich than lean anyway.
Old Aug 22, 2009 | 10:27 PM
gerrynolan's Avatar
Don't run 'er too hard like that until you Rejet. If it's running lean enough to kill power then she'll get hot.
82ltd
Aug 26, 2006 06:02 PM
