Helmet cam mounting
Old May 20, 2009 | 09:26 PM
Here is my setup. I just point and hit record.
Old May 20, 2009 | 09:52 PM
punkenduro09's Avatar
deej, i would break that off in 10 mins, and if it didnt, i would make the viewers sick. i working on a cardboard case im putting a old camra in to tape to my helmet. i would go film my local trails, if the bike can keep running...
Old May 21, 2009 | 06:06 AM
kmac250's Avatar
Here are some photos of how I attached an Oregon Scientific ATC2k. I found a spot on the helment that would point the camera forward in line with my eyesight then used 5-minute epoxy to to glue the supplied mount to the helment. Before gluing I used some fine grit sandpaper to rough up the surface of the helment and mount for a better bond. I used some masking tape over the mount to hold it in place while the epoxy cured.
The ATC mount allows you to rotate the camera in two directions so I now can move the camera view up or down plus rotate the barrel to get a level horizon. I try to aim slightly up but still capture some of the handlebar and front wheel action like Nobrakes talked about.
Also included are pics of a Ram Mount on the handlebar. It is a secure mount and have never had a problem with spills. The videos tend to have more bounce, blurr, and vibration effects.
Hope this helps....good luck....and post your vids!
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
Handlebar mounting for ATC camera & a Panasonic flash drive camcorder:
[IMG][/IMG]
[IMG][/IMG]
Old May 21, 2009 | 07:36 AM
neilaction's Avatar
Thanks guys.
I will post some vids when I next head out.
EMS_0525
Apr 15, 2008 01:51 AM
002197rp
Jan 1, 2008 03:20 PM
klx250s_rider
Aug 10, 2007 03:12 PM
Davebert
Jul 30, 2007 05:56 PM
preemo_21
Nov 9, 2006 02:18 AM
