Headlight problem
Old May 26, 2007 | 03:43 AM
skootercee's Avatar
Default Headlight problem
[sm=WTFsgign.gif]For som reason my headlight and tail light wont work, every all other lights work fine. When I checked for voltage I had no reading. Is there a relay or fuse I can check
Old May 26, 2007 | 02:57 PM
Bluebeast's Avatar
Default RE: Headlight problem
there should be a fuse some where on your bike. it's probly under your seat. since kawi likes to put them there.
Old May 26, 2007 | 05:07 PM
dmar's Avatar
there are 3 fuses, check the owners manual for location.
Old May 27, 2007 | 01:14 AM
CALISAKI's Avatar
they are under the seat, i had one blow on me too. very easy to fix. i also had to replace the headlight bulb shortly after that. do not get the oem replacement bulb as it is way overpriced. just go to any autoparts store and they should have the equivalent bulb for about $50 less than oem. i think the bulb isnt over 16 bucks. but oem i think is like 60 something, and the wait to get it. ok good luck.
[IMG]local://upfiles/1706/C8CDC43022FD458E8A1BD4F871E5D4DF.jpg[/IMG]
sysroot
Oct 25, 2012 06:15 AM
Thad-deus Coan
Ninja 250R
Sep 13, 2012 06:11 AM
Savagekilla
May 16, 2008 10:22 PM
teriyaki_rocket
Ninja 500R
Aug 3, 2006 07:12 AM
