Head bolt torque 34ft/lbs ? 8mm Allen
Old May 9, 2019 | 11:30 PM
ctbale's Avatar
Default Head bolt torque 34ft/lbs ? 8mm Allen
So the information I have for head bolt torque is initial torque to 11 foot pounds then final torque to 34 foot pounds. Seems like a lot for an 8 millimeter hex. Is that what you guys are doing? I'm guessing anti seize the threads also. That's what I do for most of my engines. Looks like the factory used black moly grease. they were tight tight tight
Waiting on a new head gasket. Every day goes by I'm super tempted to throw the old one in there and ride this thing! Haha
Old May 10, 2019 | 03:32 AM
GBAUTO's Avatar
That's for the 4 main head bolts. The small bolt buried down in the cam chain housing(#5 in the manual) only gets torqued to 106 inch/pounds. Others have discovered the hard way about this difference. DO NOT reuse the gasket(unless, of course, if you enjoy repeating tasks).
Old May 10, 2019 | 07:00 AM
ctbale's Avatar
ouch! 34ft-lbs on a 6mm fastener!!
I have a "calibrated" elbow for old horz hondas but breakin out the torque wrench on this one.
ok, am going with the book 34ft-lbs and 106in-lbs for the side screws.
Old May 10, 2019 | 03:04 PM
GBAUTO's Avatar
Now you see the difference-head bolts are 10mm and take 34#/ft(that's 408 pound/inch) while the 6mm bolt only takes 106 #/in.
Old May 10, 2019 | 07:27 PM
ctbale's Avatar
the honda ct70s I had been restoring have 4 loooong 6mm head bolt/studs with one side screw. if memory serves, those were 100in-lb. thats pretty much a normal range for 6mm fasteners.
durielk
Aug 8, 2011 05:31 AM
wild will
Jun 14, 2009 02:07 PM
My.klr.jr
Jan 18, 2009 06:57 AM
blacktail
Jun 10, 2007 05:30 AM
gtlandry
Oct 3, 2006 06:32 PM
