Handlebar Bend For Short Rider
Old Oct 7, 2012 | 11:34 AM
MauiBoy808's Avatar
Default Handlebar Bend For Short Rider
Hey guys,
I was just wondering, what is the rule of thumb for short riders (5'6" - 5'7") and aftermarket handlebars? Should I get higher/lower bends? wider/narrower bends? less/more sweep/pull back? compared to the stock 2009 KLX250S bars.
I know they are purely preference but I have no way of knowing how they feel without them being mounted.
Thanks all.
Old Oct 7, 2012 | 12:01 PM
GaryC's Avatar
Originally Posted by MauiBoy808
Hey guys,
Thanks all.
I like the ATV high bend and i am 5'7". you will have to get a 2" longer clutch cable (#54011-0009) and re route the throttle cables for additional length.
Old Oct 7, 2012 | 03:34 PM
punkenduro09's Avatar
i would say figure out if you want the bars higher or lower, and then go to a good shop and feel the bars in your hand, it makes a huge diffrence. i would say if your worryed about being short, try looking at a ricky carmichael bend, he was pretty short.
Old Oct 7, 2012 | 04:20 PM
wildcard's Avatar
How about these ?
Old Oct 7, 2012 | 07:46 PM
zomby woof's Avatar
I'm 5'7" and I like low bend Suzuki RM bars on my KLX, but I tried them on my vintage bike and hated them.
This should give you some ideas
Motorcycle, Dirt Bike, and ATV Handlebar Measurements and Information
Old Oct 8, 2012 | 07:40 AM
MauiBoy808's Avatar
Thanks for the input guys. Anyone know the theory behind how bars should be for shorter people. In theory, should they be running low bends as opposed to high bends? I know it's preference, but technically what is better?
Old Oct 8, 2012 | 11:06 AM
Subasaki's Avatar
love the CR hi bend renthals...more comfy,and im short armed
Old Oct 8, 2012 | 12:21 PM
doum's Avatar
FYI 5'7" is not short, most of the bike are design for people that size because it's in the average range.
If you ride your bike a lot while standing up on the foot pegs than you would like to have the handlebar higher to be more confortable. If you like riding in tight trails in the wood, having narrower handelbar will help you. If you do a lot of highways don't forget that with aftermarket handelbar you lose the weight at the each end (inside) the stock handelbar that helps stabilizing the bike. And if you want rock solid handle bar go with the 1.25", the adapter will make them rise so you can get a low bend to get back to normal height. I hope that helps, good luck with your choice.
Old Oct 9, 2012 | 01:07 AM
toyotabuilder's Avatar
my lady is 5'2'' and runs cr highs the are like stock klx bars i personaly hate low bars as i'm 6'3'' its really going to be up to what you prefer and how you like to ride i finaly started running raptor bend protaper so i don't have to lean to stand
Old Oct 9, 2012 | 03:26 AM
MauiBoy808's Avatar
I'm thinking I'm gonna go with the best of both worlds and just get a klx mid bend or something. Is this a decent option? Also, at what height do you need longer cables? I've read some posts but found conflicting results.
