got a new KLX 250S 2 weeks ago
Old Dec 15, 2014 | 02:12 PM
Duomike's Avatar
Default got a new KLX 250S 2 weeks ago
Really like the bike. I live in Indonesia and it replaced a 200 cc locally made Honda street bike. The KLX is a lot more powerful than the Honda and I do not intend to mod the engine. With that traffic here I hardly ever go fast than 50 mph. mainly ride on road and the bike is really great handles a lot better on mountain road than my little Honda.
Installed a Givi topcase and seatconcept seat for my touring.
Got 2 questions. Am I imagining things or did the bike increased it's power during the break in process? Also engine seems to run smoother than when I first got.
The headlight is decent but not good. Acc to the manual it's a 25/30 watt bulb.
Is it possible to install a standard 55/60 watt bulb and hob difficult is it.
regards from Lombok/Indonesia
Duomike
Old Dec 15, 2014 | 07:18 PM
rgmr250's Avatar
It's not uncommon for an engine to perform a little better after break-in. Usually the difference is very minor and often only measurable on a dyno, though.
Re headlight, I'm pretty sure the North American bikes come with a standard 55/60 watt bulb, so swapping in a standard bulb should be no problem. I don't know why they'd include a measly 25/30 watt bulb?
Old Dec 16, 2014 | 01:41 PM
Duomike's Avatar
Thanks for your reply!
How to disassemble to headlight in order to change the bulb. There is nothing in the manual
Old Dec 16, 2014 | 08:40 PM
rgmr250's Avatar
You need to take the headlight shroud/numberplate off first - two bolts on either side, just above the headlight. One bolt below the headlight, just above the fender. I've found that the shroud won't come off without at least loosening the 4 bolts holding the front fender on - I usually loosen the 2 rear ones and remove the 2 front ones. Then the shroud comes right off. Then, IIRC, there's a bolt on each side of the headlight and then it comes out so you can access the bulb at the rear. Pull back the rubber shroud/seal, then there's a clip holding the bulb in - you need to press down on one side and then move it to the side to unhook it, then the bulb should just come out.
Old Dec 17, 2014 | 01:08 AM
Duomike's Avatar
Thanks a lot!
Old Dec 17, 2014 | 02:20 PM
Hey Duomike welcome to the forums.
Old Dec 19, 2014 | 01:05 AM
MaximusPrime's Avatar
Or you can pull off the fender and reach up in from underneath to change the bulb...less stuff to get back in place that way.
Old Dec 20, 2014 | 12:39 AM
Duomike's Avatar
Besides the fact that the light is not very bright it's beam is also a bit low too. Tried to adjust it with the screw underneath but no matter how much I turned it nothing happened. Something wrong for sure. I'll buy a new bulb next week and have Kawasaki fix that problem and at the same time change the bulb. Luckily labour is extremely cheap here.
Old Dec 24, 2014 | 02:04 PM
ianmcdca's Avatar
I`ve adjusted the headlight angle on my bike...its not a great system for sure. If you loosen the screw at the bottom (for height adjustment), you actually have to manually pull up on the light to raise the angle....even doing that its not much higher, but it works.
Ian
Old Dec 27, 2014 | 12:01 PM
Duomike's Avatar
Ian,
pulling up did not help. Went to the local dealer and ask them to fix the lamp and at the same change the bulb. Took them 15 minutes. Surprisingly the oem bulb is a Phillips with 55/60 watts and not 25/30 as per t5he manual. Never mind, now I got a spare bulb. For changing the bulb they charged my 2 bucks only!
ludikris
Aug 5, 2007 08:53 PM
Fuzzy636
Jan 17, 2007 07:10 AM
onestarr99
Nov 4, 2006 01:35 AM
TempeTy
Ninja ZX-10R
Sep 14, 2006 05:35 AM
ntloser
Aug 26, 2006 10:19 PM
