Glowing Red Headpipe on 351 BB
If I read the Mikuni data correctly, the 9EBY01-50 is richer.
Also what is the difference between a needle jet and a jet needle
For example, Needle jet: P4, Jet needle: 9EBY01-50
I purchase the needle jet P4 and was surprised to see the tube the needle slides into (well) and not the needle. I changed the needle jet from the stock P8 to the P4.
Thanks for the help. I'll order the correct needle. While I have your ear, I have a considerable amount of poping when the RPMs are falling and throttle is closed. I'm thinking the new needle would help with this. Idle air adjustment?
My header glowed when I first installed. Here's what did (aside from carb setup in my sig):
1) double checked joints were sealed properly on exhaust, including where header attached to cylinder
2) went back in and re adjusted my timing...mine was a touch off, even after I thought I had it correct when it went back together
3) burped and refilled my coolant with moto-ice
4) clipped the jet needle 4th from the top (I'm figuring my setup was a little too lean)
Seems to have made a difference, doesn't appear I have any more glowing and engine runs smoother...gonna keep an eye it when it gets hotter tho...
Thank you!
Thanks for the link, that will help for the set up. I'm sure after I get the correct needle evert hinges will be good.
How many turns out did you guys set your idle mixture screw? It's tight to get in thee so a base point would help.
