Gen 1 VS Gen 2 differences??
Can sombody post a list or link of the differences between the Gen 1 and Gen 2 KLX? I see the Gen 2 has a new electronic guage which is nice. And panels are different shapes. Any other differences?
Also I noticed the Gen 1 has another inch of travel. Does this make it a better off road machine? |
I think gen2 look better. The inch of travel is debatable, the suspension is low budget on both generations. But for its intended purpose works quite well. I know the search function kinda sucks but give it a try you could be up for days soaking in all the good info on this site. There are also some really knowledgeable and truly nice people on here.
Here's one that comes to mind.
The gearboxes are different. Gen 1 6th gear is taller. Some describe Gen 2 6th gear as "fifth and a half." Not significant for many riders. |
Front brakes much be different - couldn't get pads in Thailand which sells what you are calling the gen 2 and i have what you are calling the gen 1 (for the most part).
On that note, found a perfect match for front brake pads with the Honda XR250L. |
Gen 2 wheels are stronger, but much heavier (thicker gauge spokes etc), Gen 1 has a better front disc (floating) Gen 2 has a solid unit. Gen 1 has an idle screw that has a remote for on the move adjustment, Gen 2 just has a screw. Gen 1 has fork bleeder screws, Gen 2 doesn't. Gen 1 gets a rack, Gen 2 doesn't. Gen 1 had 'snail-cam' adjusters for the chain, Gen 2 has nut/bolt adjusters. Different swingarms on both bikes.
KLX250S (gen 1) is a softened version of KLX250R. KLX250S (gen 2) is a softened version of KLX250S (gen1) |
I have an '07, ("gen 1") and I love it, and if I had to choose again, I would still choose the "Gen 1" with the looks and the extra suspension travel being the deciding factors for me.
That being said, I think the differences between the two are more cosmetic than anything else. Yes, there are some minor mechanical differences as mentioned above, but I think you would be happy with either version. |
"Gen 2" has a bigger rear disk brake with Wave rotors at both ends.
I prefer the lower seat height (-1" of wheel travel) of the "Gen 2", better handling all around. |
Originally Posted by cmott426
(Post 464369)
Thanks for the info guys. Im leaning towards the Gen 1. I think i prefer the look of the older one. I already have a street bike so this will be used 80% off road, could probably use the extra inch travel. The Gen 2 did look low to me. And most of all I can probably get a Gen 1 cheaper and spend the savings to get some power. The higher 6th gear sounds like a bonus for on the highway too.
Originally Posted by mmurray70
(Post 464326)
Also I noticed the Gen 1 has another inch of travel. Does this make it a better off road machine? 2009 KLX |
