gas mileage with tm36-68
Old Jun 8, 2011 | 03:50 PM
T_i_G_e_R's Avatar
Default gas mileage with tm36-68
I put the pumper back on after my back healed.. 65 mpg putzing around the island.. this is 10mpg better than I got with the cvk.. anyone get similar results?
seems like a no brainer, 10-15% more torque on the bottom end and midrange, 5mph increase on top speed, and 10 mpg increase with the tm36-68
Old Jun 8, 2011 | 04:37 PM
red's Avatar
red
i'm bouncing between 60-71mpg with the stock carb on my 09 sf depending on where/how i'm riding. most my riding is around 40-55mph, want to get the pumper carb when i do the 351 kit late this summer/early fall
Old Jun 8, 2011 | 06:43 PM
T_i_G_e_R's Avatar
I had to stiffen up the rear damping and tighten down the rear shock because of the torque from the tm36
Old Jun 8, 2011 | 07:34 PM
red's Avatar
red
lookin forward to that! could use some more torque at the bottom end on these bikes to get the front end up easier
Old Jun 8, 2011 | 07:37 PM
David R's Avatar
57 to 62 mpg, average 60. This is with the 351 and tm36-68 carb. I commute to work and ride around. I spend a lot of time at 60 or so mph. 15/39 gearing.
Back tire is wearing fast......
David
Old Jun 8, 2011 | 07:58 PM
RayTard's Avatar
David
How do you like the 15/39 gearing??
Old Jun 9, 2011 | 03:25 AM
Mr.P's Avatar
Does this carb fit properly on the 09+ bikes?
Old Jun 9, 2011 | 04:58 AM
2007KLX250S's Avatar
David
How does the 15/39 do at highway speeds? I went with a 16/42 and can do 80 indicated at 7k rpm. (if there is any wind though its rather slugish) I just think the 16tooth cs is too big and want to go to the 15. I'm also still just a 250 but the 351 is being installed this winter!
Old Jun 9, 2011 | 12:52 PM
David R's Avatar
Since a couple asked,
The 15 tooth is perfect for me. I get 61 mph indicated at 6,000 rpm with almost no vibration. With the 14/39 the engine was closer to 7,000 rpm and vibrated pretty good.
Also I wanted to try and keep the MPG up since I went to the bigger engine. Bike has tons of torque even with the 15/39 in 6th gear. I LOST the ability to do throttle wheelies in second gear.
With the 250 and 14/39 I could not use high gear in a strong head wind. Now It pulls in high NO problem even with the 15/39.
It was just a try it thing, and now the 15 tooth stays.
6,000 Rpm = 61 mph
7,000 RPM = 71 mph
8,000 rpm = 81 mph
Thats all she's got. I have seen 89 out of it once.
Speedo is off 7% according to the GPS. Odometer is right on.
Now to pass a car when I am going 50 or faster, just turn the throttle, no need to shift. It zooms right by em. When I pull back in, I am doing 75 to 80.
David
Old Jun 9, 2011 | 05:31 PM
T_i_G_e_R's Avatar
yea bolt on uses stock throttle cables
