funny sound on start up
Old May 3, 2012 | 04:57 AM
Burnout Hog's Avatar
Default funny sound on start up
Hi I have started hearing a tapping sound when first firing up in the mornings.I heard somewhere to use a thinner oil in the colder months so the oil rises quicker in the engine.
I put in some valvoline SAE 15w-40 but can still hear the tapping..the bike is still running well ( can anyone Help )
Thanks Tom
2009 KLX 250's
Old May 3, 2012 | 05:05 AM
Brieninsac's Avatar
Sounds like valves to me.
Old May 3, 2012 | 05:13 AM
redpillar's Avatar
Sounds like timing chain noise. There are a million posts here on the subject. Just try the search feature and you will find them.
Old May 3, 2012 | 10:33 AM
klx4me's Avatar
What is the basis of your diagnosis? Please give a reason as it gives the OP a better understanding of why/what is occurring & assists with fixing the problem. Share your experience.
Old May 3, 2012 | 11:35 AM
MaverickAus's Avatar
More than likely timing chain
Old May 3, 2012 | 01:27 PM
Borg's Avatar
My bike has a very apparent tapping, pretty sure it's the KACR...
I have a Krieger tensioner.
It totally disappears above 1500rpm maybe a bit lower, but when idling, it's apparent.
Old May 3, 2012 | 01:41 PM
Malves's Avatar
Most likely to be cam chain. I bet the tapping sound comes up between 5k-6k rpm, as well, right?
Old May 3, 2012 | 04:18 PM
whyzee's Avatar
Thanks Tom
2009 KLX 250's
WOW. What oil DID you have in there before you went to the thinner 15-40? The manual calls for 10-40.
Old May 3, 2012 | 07:27 PM
fooswolf's Avatar
I thought the Cam Chain made most of its noise after 5000 rpm. Does the valve noise tapping decrease as the bike gets warmed up? Mine did that when I got it out this year. It seemed to lessen the more I rode it. I had the valves checked less than 500 miles ago. I am using the proper oil though.
Old May 3, 2012 | 09:39 PM
ahnh666's Avatar
my 2009 klx250s/sf manual recommends:
sae 20w-50 for 0 to 40+ degrees celsius
sae 20w-40 for 0 to 40 degrees celsius
sae 10w-50 for -10 to 40+ degrees celsius
sae 10w-40 for -10 to 40 degrees celsius
sae 10w-30 for -10 to 30 degrees celsius
