front sprocket removal
OK!! So I've been in the garage the past couple weeks doing my mods. Airbox, muff, jets... 46t and chain. I have a 13t that I want to put on BUT CAN'T GET THE DAMN OLD ONE OFF!!! I had the bike in gear, sitting on it, w/ my dad using a 3ft pipe and it did nothing. It didn't budge. Any clues. We are stuck using hand tools. so don't mention some crazy cool impact. Thanks for the words of wisdom. Is it reverse by chance??? (I wouldn't think so but...)
That is an almost universal problem on these bikes. Impact wrench does the trick, but if you can't find anybody with one, you could try it this way. Like Gobius said make sure your washer is really flat. Get your 3' wrench set up on the nut and put some good pressure on it. While holding the pressure have someone tap the nut, or the wrench close to the nut. Sometimes the combination of the pressure from the wrench and the vibrations from the tapping will get the nut loose. I have put anti-sieze compound on mine when I reassembled it, to try and prevent the same condition the next time i change sprockets.
Good luck
Dan
PS search on here it's been discussed quite a bit. lots of good info if you look.
Good luck
Dan
Good luck
Dan
Good luck
Dan
Just be carefull with antiseize inside the engine. It is esentialy made up of bits of soft metals like coper and lead suspended in oil solution. Inside the engine it will pormote wear. Outside its good stuff.
i used a 1/2 inch breaker bar with a 3 foot pipe. i wouldnt use a rachet (broke a couple with a pipe) or a 3/8ths breaker (broke one the pipe also). like it was stated before, the jerks help and dont do it in gear.
