Front brake rotor
Quick question......I'm looking for a cast rotor that fits the KLX.I believe the KDX200/220 rotor is the one......just looking for any input.I already have a KX125 rotor that sux so i have heard that the KDX rotor is the way to go.....I'm also adding new pads at the same time.....the stockers have made it for 5200 miles and they only have 2mm left.....time for change...
I wanted a new Cast KDX rotor and a set of EBC pads to go......Hopefully someone could shed some more light on the subject.The '00-'03 KDX # is different but shares the same fiche # so i'm pretty sure it will fit....
BUT I'm not going to spend 220$ for a rotor from Kawi so i was going to get one from EBC or Galfer......for 96$ and better quality.
The KDX200/220 rotorfits the KLX250S hub perfectly. The Kawasaki PN is 41080-1377 The corresponding years of KDX200 are 1995-2006. KDX220 model years are 97-2005.
OK...I found a rotor I want ...EBC#MD6015C supercoss contour.
Any recomendations on pads???? I think i found about 30 kinds....
was hoping to match a set of EBC pads to the rotor but DP and Moose have a set that look like they'd work well.....remember mud and sand resistance is the least of my concern...it's how fast they will stop is the most important.I'm leaning towards the Moose XCR pads.
On EBC...if they also note it to fit the KLX300 it wont fit the 250S--it cant--they have two different mounting bolt sizes. So make sure it is right---maybe they have their act together now but I know Dennis Kirk for example, listed EBC rotors to fit the 250s that didnt. I found all this out doing research for a SM brake rotor for the S. In the end Iordered a EBC KLX300 rotor butknew going in I had to madify it to fit the S (& I did have to).
[ul][*]Part 196994 fits the following machines:[*]1993 Kawasaki KDX200[*]1994 Kawasaki KDX200[*]1992 Kawasaki KDX250[*]1993 Kawasaki KDX250[*]1994 Kawasaki KDX250[*]1994 Kawasaki KLX250R[*]1995 Kawasaki KLX250R[*]1996 Kawasaki KLX250R[*]2006 Kawasaki KLX250S[*]2007 Kawasaki KLX250S[*]1997 Kawasaki KLX300R[*]1998 Kawasaki KLX300R[*]1999 Kawasaki KLX300R[*]2000 Kawasaki KLX300R[*]2001 Kawasaki KLX300R[*]2002 Kawasaki KLX300R[*]2003 Kawasaki KLX300R[*]2004 Kawasaki KLX300R[*]2005 Kawasaki KLX300R[*]2006 Kawasaki KLX300R[*]2007 Kawasaki KLX300R[*]1993 Kawasaki KLX650A KLX650R[*]1994 Kawasaki KLX650A KLX650R[*]1989 Kawasaki KX125[*]1990 Kawasaki KX125[*]1991 Kawasaki KX125[*]1992 Kawasaki KX125[*]1993 Kawasaki KX125[*]1994 Kawasaki KX125[*]1995 Kawasaki KX125[*]1996 Kawasaki KX125[*]1997 Kawasaki KX125[*]1998 Kawasaki KX125[*]1999 Kawasaki KX125[*]2000 Kawasaki KX125[*]2001 Kawasaki KX125[*]2002 Kawasaki KX125[*]1989 Kawasaki KX250[*]1990 Kawasaki KX250[*]1991 Kawasaki KX250[*]1992 Kawasaki KX250[*]1993 Kawasaki KX250[*]1994 Kawasaki KX250[*]1995 Kawasaki KX250[*]1996 Kawasaki KX250[*]1997 Kawasaki KX250[*]1998 Kawasaki KX250[*]1999 Kawasaki KX250[*]2000 Kawasaki KX250[*]2001 Kawasaki KX250[*]2002 Kawasaki KX250[*]1989 Kawasaki KX500[*]1990 Kawasaki KX500[*]1991 Kawasaki KX500[*]1992 Kawasaki KX500[*]1993 Kawasaki KX500[*]1994 Kawasaki KX500[*]1995 Kawasaki KX500[*]1996 Kawasaki KX500[*]1997 Kawasaki KX500[*]1998 Kawasaki KX500[*]1999 Kawasaki KX500[*]2000 Kawasaki KX500[*]2001 Kawasaki KX500[*]2002 Kawasaki KX500[*]2003 Kawasaki KX500[*]2004 Kawasaki KX500[*]Don't see what you want?[*] Click here to see the next Part number.[/ul]These are the listings for that rotor.and if i stand corrected the KDX200/220 rotor will fit.just showing you the listings....and what did you have to modify??? I'm asking before i buy a different rotor now.I figure it would work....for what it costs a 15$ cost at a machine shop is nothing compared the the 225$ an OEM KDX rotor would cost.....
My only point is that it is specifically listed under the KLX250S '06/'07 section so i would assume it would work......but never assume as it makes an *** out of U and ME.....
[/align]
[/align]
a KLX300 front rotor will not fit as KLXer said. I know firsthand as I bought one for my '06 KLX250S because I liked the way it was cut better than the oem 250's. I actually found a stock one for around $20 or so on ebay. I got it and went to put it on and the bolt mounting holes are smaller in diameter than the 250's. It got sent back to the seller as he claimed it would fit the 250S, I should have done my homework more. Sure you could have someone machine them larger, but the holes aren't straight through as you'll see if you remove your rotor. There is a shoulder that the head of the bolt rests on so it will not stick out and hit the inside of the fork. Alot of those rotors listed aren't iron like you said you want unless those weren't oem's in that case I don't know. I'd look for a used oem KDX rotor and call it a day. You just bolt on and go, no messing around with a machine shop.
edit: this is an example of a brake rotor that will NOT fit your bike. don't confuse the KLX250R with the KLX250S because these rotors will fit the R model as that is really the bike the KLX300R was before '97.
http://cgi.ebay.com/ebaymotors/KX-KD...spagenameZWD1V
