Flashing neutral light
Old May 28, 2011 | 03:23 PM
ol'klx-er's Avatar
Originally Posted by Mcnutts
Took alot of stuff off today to look at the wiring, to look for the problem with the "shorting". With the ignition on and wiggling wires, I couldn't get the computer to reset. Everything looked OK. Maybe a damaged cell in the battery?
I don't think it's a short. As you said maybe the battery is dying so the voltage on crank is dropping low enough to cause the reset. Or a bad ground somewhere. A bad ground would cause voltage to flow back through the system searching for a ground somewhere/anywhere. You've probably been behind a car at night with two tailights on, then you get to a stop and the car in front has just one brake light, the other side has no lights at all. Bad ground on the dark side. The brake filament voltage is "grounding" itself through the tail light filament. 12V on both sides of the tail filament = zero current flow = neither filament lighting.
BigSl!ck
Nov 7, 2023 11:59 PM
dusan498
Oct 6, 2010 03:01 PM
kmd3
Jul 11, 2009 07:15 PM
jimbo59153
Ninja ZX-9R
Jun 29, 2007 11:30 PM
sweetsrt4
Ninja ZX-10R
Jun 20, 2007 12:06 AM
