First Service
Old Jul 24, 2013 | 07:09 PM
  #31
Lotrat's Avatar
Originally Posted by IDRIDR
You cannot tell the perfect interval by looking at the oil. If this interests you enough, do used oil analysis testing at mileage intervals and determine when the oil needs replacing.
I left the bobistheoilguy forum years ago. No more UOAs for me, I just throw lots of fresh dino oil at my motors. I never keep them long enough to care. I only keep them for 150k and dump them before the motor blows.
Old Jul 24, 2013 | 11:52 PM
  #32
Highbeam's Avatar
This bike only uses 1.5 quarts of relatively low grade oil. You should use oil that meets the spec. I like synthetic myself.
So change early and change it often. What about the oil filter? It is very easy, cheap, and clean to just change the oil but changing the filter is much more money and mess.
Does anybody just change the oil and leave the filter alone?
Old Jul 25, 2013 | 12:54 AM
  #33
Yep, I do a 2-to-1 oil to filter change regimen. Since my trip scenarios usually involve well over 1000 miles at a whack, I usually change it when I get home, so I'm probably averaging about 1200-1400 miles on the oil and about 2400-2800 miles on a filter. I inspect the old filter, and I've never seen any degrading of the paper element or any collapsing of the paper folds...always looks good. I use 10-40 synthetic oil. This bike uses absolutely no oil between changes. I'm impressed as I've never had another bike that gets flogged this hard that didn't use at least a little bit of oil in the same conditions.
Old Jul 25, 2013 | 02:02 AM
  #34
wildcard's Avatar
I do a two to one also on both bikes and car. no reason to toss a perfectly good oil filter (assuming just a regular oil change, bike wasn't dumped into a creek or something) and make a bigger mess.
Old Jul 25, 2013 | 02:38 AM
  #35
DustyCowboy's Avatar
Originally Posted by NorCalKLX
Yeah it gets dark fast. After thinking it through, it makes you wonder why the recommended service interval is so high. Especially if the oil is shared. Not sure I want friction material lubricating my cylinder wall.
Where did you find your info? In the same owner manual that suggest you to shift in 6th gear at 34 mph?
You may draw your own conclusions...
Old Jul 25, 2013 | 04:40 AM
  #36
NorCalKLX's Avatar
I think manufacturers do this for two reasons. A:lowest maintenance so they can brag and B:by the time maintenance matters the bike, car or equipment is out of warranty.
Old Jul 27, 2013 | 01:42 PM
  #37
Jules083's Avatar
I'm also wondering about the valve check being so high. I know some motors don't move much, but I'm planning on doing the first few checks early to see what's really going on in there.
mapleredta
Ninja 250R
14
Apr 4, 2008 06:53 PM
Oldone
Ninja 250R
Aug 30, 2007 04:38 AM
Firedude
Oct 4, 2006 02:12 AM
SERGE
Mar 4, 2006 08:50 AM
cody
Jul 12, 2005 09:05 AM
