First Post, 340 Kit Install etc.
Old Dec 16, 2016 | 04:29 AM
Ruggybuggy's Avatar
I'm running a 351 cylinder and using the TM36-68 pumper. Once i had the carb dialed in I wouldn't even consider going back to the CVK. Its an amazingly responsive carb. I always had a hesitation when I cracked the throttle on the CVK which I couldnt resolve. The TM36 with the pumper has an insant response. RPMs rise very quickly compared to the CVK.
Old Dec 21, 2016 | 04:47 PM
LaGrasta's Avatar
lowering the passenger pegs… early KLX (KLR) had them mounted on the swing arm. You may want to consider this.
Old Dec 21, 2016 | 08:00 PM
fasteddy's Avatar
Thanks for the idea, I will look into it, also another idea has been put forward, I will report on it if it proves out..
Old Dec 21, 2016 | 11:47 PM
Ruggybuggy's Avatar
Also you mentioned that you wanted a quiet exhaust with a HP increase. Use the KLX300 exhaust with a new end cap. These are hard to find. The KLX300 didn't use a cat and retains the spark arrestor. Also it's stronger than a aftermarket so it won't dent if you drop the bike.
Old Mar 25, 2017 | 12:52 PM
fasteddy's Avatar
Default Stumble
Have put about 300 km's on the 340 so far, engine runs strong, I really like it, although at highway speeds an erratic stumble is troubling me. I have read that it might be an electrical issue of some sort, a grounding issue or a voltage regulator issue. Wondering if there anything definitive on this?
On another note, new suspension springs front and rear will be here Monday and a rear rack will arrive as well, the bike is coming together nicely..
Thanks
Old Mar 28, 2017 | 02:15 AM
fasteddy's Avatar
Default Stumble fixed
Did the ground mod, stumble is gone... Also installed new suspension springs front and rear, awesome difference in ride and handling. Liking the bike more and more.
Ed..
Old Mar 28, 2017 | 04:40 PM
It's a great feeling having a bike come together.
Old Apr 3, 2017 | 05:36 AM
fasteddy's Avatar
Ed..
I take that back, stumble is still there, it's subtle, but there and it bugs me, gets worse as the bike warms up or is under load when heading into the wind, starts around 5000 and goes to 6000 or so. My jetting is 128 main and dj spring with dj needle set at 3rd notch, left pilot alone, air/fuel screw at 3 turns out. It's almost as if the slide is hunting, not holding it's place at a that RPM and a constant throttle setting. Wondering if it could be as simple as going back to the stock spring?? I'll have give that a try tomorrow.
Old Apr 3, 2017 | 07:37 AM
timc63's Avatar
fasteddy,
I don't know what elevation you are at but but with a 128MJ, could you have a lean stumble?
TC
Old Apr 3, 2017 | 11:55 AM
fasteddy's Avatar
Originally Posted by timc63
fasteddy,
TC
I'm at about 500 Ft, the weather has been on the cools side, 10 deg C, the bike does seem to run pretty hot although the fan has never come on. I will go up one size on the main, just to see, one change at a time.
Ed..
