Finally
Old Apr 13, 2008 | 01:47 AM
LearjetMinako's Avatar
Default RE: Finally
For the cost of 2qts of oil and a filter. I don't mind changing the oil every 1k miles. Just driving the KLX the same mileage as the truck. I save enough in 1x tank full of gas on the KLX to afford the cost of the oil change.
If it runs, its still good. I've seen worse as a mechanic. Just try a little bit more tender loving care for the KLX.
Old Apr 13, 2008 | 03:19 AM
Will Shoe's Avatar
Default RE: Finally
Its alright about the longevity of the engine because I have a KX250F motor that I found will fit perfect in the KLX. If I don't want to monkey with the 250F I was thinking of getting the 330 bore. The reason I left it go so long is because I never had the time to change it and every time I went to my dealer they said they didn't have a filter in stock so I ended up ordering one over bikebandit.
Old Apr 13, 2008 | 03:26 AM
tremor38's Avatar
Default RE: Finally
Umm...yeah, just bolts right in . 'Monkeying with it' would involve more than just fitting the engine. How about a KX250F CDI and wiring harness for starters, then an after market stator and some some sort of dual sport kit that includes a smaller battery and regulator if you want to keep your lighting.
Dependability will drop, because the engine has higher performance and compression. You will have to burn premium gas and I wouldn't want to miss many oil changes on that engine. Start searching for a KX header and a good weld shop as well, unless you want the fullKX250F exhaust.
ORIGINAL: Will Shoe
Old Apr 13, 2008 | 04:03 AM
tremor38's Avatar
Default RE: Finally
Double post
Old Apr 13, 2008 | 04:40 AM
Will Shoe's Avatar
Default RE: Finally
I learned to weld at 11 and have thought the 250 motor through and you are right about the premium gas and oil changes.
Old Apr 13, 2008 | 04:45 AM
stellar_d's Avatar
Default RE: Finally
wow lots of feedback from not just members, but enthusiasts!
Take care of your **** will!
Old Apr 13, 2008 | 05:18 AM
Will Shoe's Avatar
Default RE: Finally
Haha thanks Stellar. But this thread was for the most part a fraud. I actually changed the oil at 600 and 1000 and 2000 and 3000 and 4000. I just wanted to see everyones reactions.
Sorry [8D]
Will
Old Apr 13, 2008 | 01:50 PM
ZX1100F1's Avatar
Default RE: Finally
A more appropriate term would be “lie”, peoples reaction to an idiot isn't much of a science project.
Once you’ve lost your credibility on a forum you become a nuisance and your posts loose value.
Old Apr 13, 2008 | 02:42 PM
lcpl0331's Avatar
Default RE: Finally
Atta boy Willya got em'. i'm a bit surprised considering how obviousit was but good for you.
Old Apr 13, 2008 | 04:44 PM
Will Shoe's Avatar
Default RE: Finally
I don't think the motor would still turn over if I went 4400 miles without a oil change.
