exhaus uggetsions to increase low end torque
KLXter is right, removal of the spring from the KACR apparently is fine. I pinned the shoes out on mine because it just made two less moving parts. When I do the valves next I will probably press the whole mechanism out. Neither Honda nor Yamaha have a compression release on their 250s when there's electric start. Now with the mechanism disabled I've never had problem one with starting.
Read the MCM article, but take a look at the condensed version linked in my sig when you go to do the work. It pretty much is step by step without the background information in it. The original could get a bit confusing as written, when you see the actual process it's pretty easy, other than the headache of getting the cams on the right teeth to align - a point where I kept ending up a tooth off or moving the wrong way... but maybe that was just me. The actual verification is quite easy once you see it.
I and some others are working on a recipe for getting the most HP and TRQ from the stock bore. The loss of low end your refering to is less a function of adding backpressure with a restrictive muffler than it is a correct sizing of the head pipe from port to muffler. I expected the Megabomb to mitigate the loss of low end ( the megabomb+PC4 have a larger I.D. head/midpipe than stock header+DG) but it did not. See it for yourself on my shoot-out thread.. Combined with the MCM, the stock header+DG slip-on and a 12-12.8:1 AFR kick major a$$ in the TRQ department...
Ride on
Brewster
That was when I did it with my 09. I wanted the cams out so there was no chance of dropping a bolt down the cam tower for sure.
If money alone was a big issue and I was to start again I'd still do the BB for slightly over $500 bucks and chop and rework the stock exhaust (free), buy a few jets ($25), pull the snorkle (free). Do all the work yourself with this forum alone and you would have a bike that was pretty damn impressive.
Or, as you read down the hot-linked page, consider a sort of very short/tapered anti-reversion cone sandwiched in between the engine and .header pipe..
Or
I used to weld up something like this hoping for anti-reversion on my XT500 decades ago... (bomb pipe?)
Definitely best bang for the buck in transforming the characteristics of the bike.
klx678
Feb 5, 2013 10:25 PM
speedracer138
Oct 10, 2007 11:05 PM
