-   -   Engine Swap? (https://www.kawasakiforums.com/forum/klx-250s-71/engine-swap-30420/)
dualsportman Sep 30, 2009 07:31 PM
Engine Swap?
Hi there!
Read a lot about the subjet but who did it actually?
What kind of engine?
Cost vs Big bore?
thanks
Eric the frenchie!
dualsportman Sep 30, 2009 07:57 PM
Can we do it with the klx 450?
It's 1600$
http://cgi.ebay.ca/08-KLX450R-KLX450...d=p3286.c0.m14
CousinLarry Sep 30, 2009 08:21 PM
Doubt the 450 will fit without a lot of fab work..
As far as swap, from what I understand any KLX250 or 300 motor from 97 on will bolt right into the frame of the 250s.. Someone correct me if I'm wrong. Easier to just swap the cylinder/piston out if you want a more CC's.. Unless your motor grenaded or something :)
TNC Sep 30, 2009 10:22 PM
There was another recent post about putting different engines in different frames. When you go outside the "series" engine and frame combination to another series model engine or frame, you almost always open a huge can of worms, requiring some heavy duty fabrication...and knowledge. Chainline issues, cooling system plumbing, and other issues can give even an experienced guru some real headaches. I've seen a couple of dirt bikes done in the past with one model chassis and another model engine, and both were air cooled engines. The best I saw was a Honda CR motocross frame with an air cooled XR250 motor. It was sweet, but it was a serious and time consuming project.
Dready Sep 30, 2009 10:27 PM
For $527 shipped to your door you can get the 351cc kit and install it yourself...seems like a no brainer to me
dualsportman Oct 1, 2009 10:39 PM
just asking before modding!!
RimBender Oct 2, 2009 01:00 AM
XR200+ motor in a CR125 frame, was WAY more work than one would think. Everything had to be moved, modded or custom built. Airbox, tank, lower frame tubes, mounts, pipe etc. With all the good bikes out there now I wouldn't even consider a engine swap.
dualsportman Oct 2, 2009 03:15 PM
Just to increase power !!
And to keep my bike cheap plated.... Here the cheappest cc to plate is under 400cc....
