Engine sounds good or bad?
Old Feb 18, 2024 | 01:35 AM
MXM's Avatar
MXM
Default Engine sounds good or bad?
Engine sound:
Bike is a 330cc kit and has a kriega MCCT fitted. But does this engine sound right or needs inspection?
Bike only has 15 k km. About 2k on the 330 kit
Old Feb 18, 2024 | 01:46 AM
GBAUTO's Avatar
I would go through the adjustment procedure on the CCT.
My 351 varies on the amount of clatter it makes from cold to operating temps.
Old Feb 18, 2024 | 02:29 PM
Read the instructions on the fine tune... Fire up the bike and warm it up, then crack the locking nut loose, slowly turn the adjuster bolt in until the clicking goes away. It should grow quieter bit by bit. Once quiet, hold the adjustment and tighten the locking nut down against the body. It does sound like the cam chain is loose. It definitely should quiet down as the adjuster bolt is turned in, but do not overtighten it. You might even feel the tapping on the adjuster bolt. It will go away there too. I've both felt and heard the tapping go away when I did a Kaw Eliminator 900.
If you don't have the instructions here is a link. click here Odds are you may use an allen wrench, just work very gently, the adjuster bolt should never be tight with an allen wrench. If you construct the "special tool" setup that TNC did in the instruction, do not use a ratchet, just turn the end of the extension by hand. All you are doing is taking the slack out of the cam drive, not putting any tension on the chain.
Old Feb 24, 2024 | 10:09 AM
MXM's Avatar
MXM
Thanks for the detailed write up and link to instructions. My mechanic visited today, read everything you provided and adjusted while I watched. He was very cautious not to overtighten. The bike sounds like it is normal again 🙏
MXM
Aug 30, 2022 11:23 AM
glevy
Apr 28, 2017 01:25 PM
peabrain
Mar 20, 2017 03:35 PM
Asterof
Aug 28, 2015 05:36 AM
markmeinteil
Ninja 250R
Nov 1, 2006 09:03 PM
