electrial issues
I pulled out the diode and put it back in with no luck, tried testing the diodes but realized I have no idea how that diode is suppose to work as it has 6 pins haha.
edit: hmm Went outside replugged in a few things, tested some voltages and then looked over at my gauge and it was on, soo I guess problem solved lol
Annddddd never mind, put the gas tank back on head light back on shrouds, try to turn it on, nothing. This is weird, going to investigate more later today.
Update: I have found the problem and momentarily fixed it. what happened was the connection point between the ignition and the system was not connecting properly and only made contact when not bent, I unbent it and resleeved it with the weird plastic sleeve that I assume is to stop people from easily hotwiring the bike. and now everything is great!
we'll I found that It was may battery (I think) Checked it and showed a low voltage after having it on charge. However after a few Months It has done the same thing. No power at all at the headlight,horn or neutral light. Checked the fuse and it was good but, I don't have power thru the relay, with key on or off and the battery is good(13volts)also only 3 months old. I had been riding for about 3 hours starting with no issues, until the last stop before heading home and when I was attempting to start it up the starter kicked in only a split second and every thing went dead.
