EBattery, TurnTech, Super B
Old May 11, 2009 | 03:00 AM
tremor38's Avatar
Originally Posted by LearjetMinako
Sounds like you know what it means.
Charging from the bike's electric system is really an easy problem to over come. Battery will just need to have the charger built-in with it. With Li-batteries, the proper charge method is a CC-CV (Constant Current - Constant Voltage). In other words, a constant current rate is applied first until the battery voltage reaches a certain point. Then it maintains that voltage until the current rate drop to a certain point.
Yes, "easy to overcome," but if the built-in 'charger' as you call it (I prefer 'regulator.') happens to fail, as it eventually will, hopefully it will fail safe, which this case would be to cut-off all charging. Results of a failure that results in allowing unregulated charging could be disastrous in the case of most varieties of lithium batteries
c10
Jul 13, 2007 06:09 PM
foonker
May 6, 2006 02:25 AM
50 Slider
Apr 4, 2006 03:49 AM
MAD KAW
Feb 2, 2006 06:44 PM
hamilton
Aug 9, 2005 02:11 AM
