DynoJet Results
Old 10-20-2007, 05:26 AM
bryantjt's Avatar
Default RE: DynoJet Results
I thought that back in the dark ages of this forum it was the other way round, in that you needed a larger DJ to match a smaller Keihin? I think Deej has some ungodly large DJ I think he has a 140 main with his no airbox lid and Muzzy setup.
  #32
Old 10-20-2007, 05:30 AM
KLXer's Avatar
Keihin Jets -------- DJ Jets
Num / Thou. ------- Num / Thou.
92.5 / 0.035 ------- 92 / 0.035
95 / 0.036 ------- 94 / 0.036
97.5 / 0.037 ------- 96 / 0.037
100 / 0.038 ------- 98 / 0.038
102.5 / 0.039 ------- 100 / 0.039
105 / 0.040 ------- 102 / 0.040
107.5 / 0.041 ------- 104 / 0.041
110 / 0.042 ------- 106 / 0.042
112.5 / 0.043 ------- 108 / 0.043
115 / 0.044 ------- 110 / 0.044
117.5 / 0.045 ------- 112 / 0.045
120 / 0.046 ------- 114 / 0.046
122.5 / 0.047 ------- 116 / 0.047
125 / 0.048 ------- 118 / 0.048
127.5 / 0.049 ------- 120 / 0.049
130 / 0.050 ------- 122 / 0.050
132.5 / 0.051 ------- 124 / 0.051
135 / 0.052 ------- 126 / 0.052
137.5 / 0.053 ------- 128 / 0.053
140 / 0.054 ------- 130 / 0.054
142.5 / 0.055 ------- 132 / 0.055
145 / 0.056 ------- 134 / 0.056
147.5 / 0.057 ------- 136 / 0.057
150 / 0.058 ------- 138 / 0.058
152.5 / 0.059 ------- 140 / 0.059
  #33
Old 10-20-2007, 05:33 AM
KLXer's Avatar
http://roadstarclinic.com/content/view/61/96/
That is for Mikuni but it explains why they are listed as differnt sizes. From the chart you can see a 132 DJ is like running a 142.5 K
  #34
Old 10-20-2007, 05:36 AM
When you said you checked the plug, did you do a chop? If not, the plug reading will be the last few seconds of whatever the engine was doing when you turned the bike off. If you didn't do a chop, the plug reading is probably just the idle circuit which may indeed be lean, but the rest of the range could be just right.
Also, I'm definitely no expert in plug reading, but I thought I heard somewhere that with unleaded gasoline and all the additives these days, it's a lot harder to do and get a consistent reading. I'd personally rely more on what how the engine is responding than reading the plug, unless you really know how, and cut the engine at the desired throttle setting, and immediately pull the plug and read it - which would usually be along the side of the road or trail.
  #35
Old 10-20-2007, 11:24 AM
sam83's Avatar
ORIGINAL: Nobrakes
Yes, did the chop. And got basically the same feedback on plug color from the DJ technicians. They suggested I restrict a little flow into the airbox and see what that does. I'll probabaly put the stock snorkle in sometime today and see what happens.
  #36
Old 10-20-2007, 11:25 AM
mudjunkie's Avatar
sorry if this seems a little off topic, but how do you properly read a plug..I ran my bike for about a week (200-300km) after rejetting and exhaust work and airbox opened...I then pulled the plug (the bike had been idle for a couple of days) and compared it to the original plug that came out of it..they looked the same to me so i figure I must be running ok..the bike doesn't bog or backfire..is this a safe assumption? The plug appears slightly tanned except for a dark ring on the last couple threads at the bottom of the plug..the stock one looked exactly the same..
  #37
Old 10-20-2007, 11:27 AM
sam83's Avatar
ORIGINAL: KLXer
I'd start at the DJ 124 & maybe scale back from there even. Lower then needle also.
I started with 128and the bike ran better when I went to 132.
  #38
Old 10-20-2007, 11:39 PM
sam83's Avatar
ORIGINAL: mudjunkie
This is what I did: I went through in 1st, 2nd and pinned the throttle in 3rd until almost redline and then pretty much hit the kill switch and squeezed the clutch simultaneously. I then coasted the rest of the way down my street and into my driveway. I figure my neighbors really enjoy my exhibition.
Then, pulled the plug. Pardon my terminology. The middle part (is it ceramic?) that surrounds the tip of my iridium plugwas fairly white from the tip all the way down to the base. I've pulled it after idling and after 1/4 throttle blipping and itlooked about the same.
I was told it should look either light tan or light gray.
That's what I did. Flame away if I got it wrong.
[/align]
  #39
Old 10-21-2007, 01:37 AM
tremor38's Avatar
ORIGINAL: sam83
ORIGINAL: mudjunkie
[/align]
That's probably the best anyone could reasonably do, unless you have a nice, long hill where you can keep it a WOT and let it stabilize. Throttle position is more important than RPM, and the longer you can keep the throttle at any given position (in this case WOT for the main jet reading) the more accurate your reading will be.
  #40
Old 10-22-2007, 07:27 PM
mudjunkie's Avatar
thx guys...I think I'll give that a try..it's 61 degrees F here today..was even warmer earlier but I was zzzzzzzzz from backshift..great day to run the bike and read that plug (properly)
kgwld1
07-25-2007 05:08 PM
SERGE
04-02-2007 08:53 PM
dmar
01-30-2007 10:25 PM
a16tony
12-09-2006 06:54 PM
txredneckmedic
09-20-2006 09:48 PM
Quick Reply: DynoJet Results
