Dynojet Help
Old Apr 9, 2006 | 05:27 AM
giacoman's Avatar
Default Dynojet Help
Hi, I am in the middle of installing the dynojet kit. This is the first time I have messed with a caburetor, so forgive my ignorance, please.
1) I have the new snorkel, I have done the crankcase mod and removed all the smog stuff. Also, I have stock exhaust and I will drill 1/2" hole in it. I am planning on using 128 jet and eclip on 4th position. Is this the right setting for my setup?
2) Is the main jet in the center of the carburetor? Do I have to remove the float bowl to switch out?
Thanks in advance for your help.
Raul
Old Apr 9, 2006 | 05:42 AM
a16tony's Avatar
Default RE: Dynojet Help
Howdy Raul, the main jet is the big brass one you see when you take the bowl off. I would suggest 125jet and third from the top. If it doesn't feel smooth in the mid-range, then go to the 4th. Your going to like the improvement.
Old Apr 9, 2006 | 05:46 AM
giacoman's Avatar
Thanks for the info. My kit only has 120, 124, 128 and 132. Can I use 124?
Old Apr 9, 2006 | 05:53 AM
a16tony's Avatar
ORIGINAL: giacoman
How about 124 and 4th. or a bit richer 128 and 3rd. I'm running a 128 and stock needle, the 125 was too lean for me.
Old Apr 9, 2006 | 07:46 AM
giacoman's Avatar
I wonder if somebody has the same setup as me. If so, what are you using?
Old Apr 9, 2006 | 04:40 PM
incabiker's Avatar
Tony when did you change it to a 125?? Have you noticed much performance difference?
Old Apr 9, 2006 | 05:38 PM
poodlenuts's Avatar
is this the dynojet kit all you guys are using
300
KAW 97-06 KLX 300
$64.89
http://www.dynojet.com/jetkits/motor...wasaki.php#250
http://www.dynojet.com/pdf/2206.pdf
Old Apr 9, 2006 | 05:45 PM
giacoman's Avatar
Yes it is. I bought mine on ebay for $48 + $10 shipping.
Old Apr 9, 2006 | 05:50 PM
poodlenuts's Avatar
ORIGINAL: giacoman
thank you sir [sm=smiley20.gif]
ebays the way to go
Old Apr 9, 2006 | 06:21 PM
a16tony's Avatar
ORIGINAL: incabiker
I screwed up(been sick all week), sorry. Good catch Bill. I was running the 125 before I drilled the exhaust. I am running the 128 jet with the stock needle. When I drilled, I lost 5mph at the top end on the freeway(too lean). I mixed up Todd and I, Jim Beam and cold medicine can do that. 128/stock needle = 125/KLX300 needle.
