Dyno Charts: MCM vs Stock Cam Timings
Old Oct 10, 2016 | 11:16 PM
Klxster's Avatar
Default Dyno Charts: MCM vs Stock Cam Timings
I have "stitched together" two of my older "MCM" runs along with Houstons4's latest "non-MCM" run.
Both bikes are running Lidless, stock header + loud performance slipons..
Even with the "stitching together", the AFR for this "composite curve" is 13:1 or more. Point is, there could/would be better MCM curves with a little more fueling than what I have here. Specifically, IMO, if my AFR above 6500 was just below 13:1, instead of just above, there may be no gap at all in upper power levels. While my final recipe of MCM+DJ140/2N+slipon+lidless (near sea level) will certainly have a richer AFR chart (therefore, likely better curves), I do not have that data/chart to show against Houstons4's latest (non-MCM) shown here...
Nonetheless, Fully "Uncorked" or not, MCM makes TRQ, lots of it below 6500 RPM..
A simple analysis:
MCM is over 16 LB FT from 5k to 6.6k, that's 1600 rpm of goodness.
NON-MCM is over 16 LB FT from 5.9k to 6.9k that's 1000 rpm of goodness.
While the peak TRQ numbers are similar, NON-MCM only achieves its' number with a little "bump" at 6750 rpm, MCM carries more TRQ far longer..
MCM follows the TRQ curve of the Stock Timing curve perfectly with about -1/2 Lb Ft from 6500 rpm on up..This can be considered within the margin of error for runs on two different DJ250i dynos..
Attached Thumbnails Dyno Charts: MCM vs Stock Cam Timings-2016-10-10-4-.png
Old Oct 11, 2016 | 12:03 AM
Klxster's Avatar
My advice on this is actually pretty simple. Take good measure of what RPM's you generally ride with.
If you generally ride below 6.5 - 7K rpm, do the MCM..
If you are generally above 6 to 6.5k, or want to maximize power above 6k, and you are certain you are going to forever keep the stock header, don't do the MCM.
If you are going to use a performance Header with a good slipon, the MCM will help maintain power below 6.5k while still allowing good benefits above - otherwise, there will likely be a "somewhat significant" loss of power below 6.5k but with even greater gains above..
Old Oct 11, 2016 | 12:34 PM
Klxster's Avatar
So, Richard Avatar and a few others that were tuning for max power at top RPM's could very well have been correct with their negative reviews of the MCM. While I believe MCM, perfectly fueled, will closely match or equal "NON-MCM" power above 6.5K, it is not out of the question that a KLX running a performance header + slipon and tuned for max performance 7-10.5k, would lose a noticeable amount of that power with the MCM.. AND, it stands to reason that my bike might pick up a noticeable amount of top end power if I un-MCM'd it .. However, I am not going to un-MCM my bike due to the very likely large loss of power below 6.5K..
Old Oct 20, 2016 | 03:21 PM
reinigef's Avatar
Thanks Klxster,
This comparison is what I was looking for! I usually shift at about 6k unless I have a reason not to...
That's one of the cool things I like about the KLX, we have super moto folks, dirt bike folks, dual sport folks and putt around geezer's like me.
A truly versatile little bike.
Old Nov 3, 2017 | 09:25 PM
RaceGass's Avatar
Def not the mod for all out hp as the mcm mod limits the rpm range 1K rpms n puts peak tq lower in the powerband. Not what I'm looking for in so cal / Baja
Old Nov 5, 2017 | 05:26 PM
Klxster's Avatar
As stated, if you require maximum trq in the 6.5k - 10.5K range, and are modding to enhance this range (full performance exhaust system, lidless airbox, proper lidless CVK setup) do not employ the MCM.. If you use a mod combo that stifles top end airflow/power - lids and snorkels on the airbox and/or stock header - you might as well employ the MCM..
Old Mar 27, 2023 | 07:34 PM
aviseqdas@gmail.com's Avatar
So I recently picked up a used 2021 KLX 300 and it already had the delkevic slip on, kdx snorker, dyno jet and a K&N filter.
I did the pair valve delete, o2 delete, secondary throttle plate delete, iridium spark plug, unifilter oiled foram filter.
Emailed dynojet for a map they said they dont recommend the 02 delete and the stock map is all they have.
Wondering where I can tune to bike to fully utilize the mods that are already in there.
Does adding the FMF Mega Bomb give any gains?
In Dallas, is there a local tuner I can take it to and get it dynoed and the dynojet adjusted?
Old Mar 29, 2023 | 03:05 PM
Klxster's Avatar
Reconnect the O2 system.
Assuming your reference to "DynoJet" means the bike has a tuner attached to it, any local dyno shop can dyno tune it.
Remove the airbox lid for the dyno tune and forever ( there afterwards ) for best performance.
Old Mar 29, 2023 | 04:07 PM
@Klxster So how're the Indians going?
Old Mar 31, 2023 | 02:09 AM
Klxster's Avatar
They are simply marvelous. They live out here with me at the Ranch, in the hangar. They get, alternately, ignored then pampered.. When my kids/ friends visit, we jump on them for a ride in the country.. I rotate them on solo rides to keep them "limbered up"..
As a side note, if what I did in here, with the lidless tune development /MCM usage, etc, could be considered "disruptive", it pales in comparison to what "Indianster" has done/is doing since 2016 in the Indian forum.. lol What I found was a huge group of sheeple being led around by morons that call themselves "tuners" - concerning Indian performance and how to mod + tune for best results. I am pretty much the "keeper of the data" and "keeper of the best known performance mod combos".. It's fun..
