Dumb Tube Question
Old Aug 30, 2006 | 01:01 AM
bryantjt's Avatar
Default Dumb Tube Question
This is a bit of a dumb question, but do I need to get bigger tubes if I get a wider tire in the front and back? I saw in the K270 post that people got new tubes but they were getting the thicker tubes, the tube size vs tire size isn't really clear to me.
Old Aug 30, 2006 | 01:09 AM
duvallgold's Avatar
Default RE: Dumb Tube Question
I was about to order a tire the other day and have the same question. The tire I'm looking at is the IRC GP1 4.60-18 rear, so if I get that tire and want a heavy duty tube to go with it, is the right size this one : IRC INNER TUBE HEAVY DUTY 4.00/5.10-18 TR4?
Old Aug 30, 2006 | 04:58 AM
You generally get a different tube for your 21 inch front vs the 18 inch back tire, but the 21 inch front can be used in the back in a pinch, i.e., you get a flat in the woods and need to fix it right there. Most tubes are sized by the rim size, though. I used a Kenda extra thick tube to help protect against flats - not for any other reason.
Old Aug 30, 2006 | 01:42 PM
bryantjt's Avatar
I know the rim size designation but its the widths that was bothering me, like for example 4.00/5.10-18 is this saying that it will fit a tire that is anywhere from 4-5.1 inches wide?
Old Aug 30, 2006 | 03:09 PM
Right.
cegusman
Jun 15, 2011 06:49 PM
klx250scott
Jan 27, 2009 12:05 PM
TheMaverick
Mar 11, 2007 08:25 AM
jared
Ninja 250R
Jul 30, 2006 12:40 AM
littledevil
May 8, 2006 09:14 PM
