down the hole we go
2 Attachment(s)
well i have now started what i will call phase one.
My wheels have been striped down to hubs and rims, and i have oredered new spokes "custum made" My rims will get a shiny black with stock hubs and spoke getting stock collor. (powder coated) The rest has been put on hold after a visit to a kawi and a yami stealer last friday. i went to a dealer not far from here with a friend who was looking at another bike, and while there i noticed the a Z300 and MT03 (naked R3). the dealer must have noticed me drooling, he came over and we started talking about my klx and plans for it, He adviced me trading in or selling my klx for larger bike dur to me having to often go on 150+ mile round trips with alot of highway driving. and maybe get either the Z300 or MT 03 after just doing my wheels pedals and just a light touch up. so for now i will hold back on the frame swing arm and for powder coating, and see what if i can get a good value or end up painting the rest and keeping it here is a shot if the rear wheel before i un spoke it. Attachment 35132 Attachment 35133 these pics remind me the value of ACF 50 since i forgot this winter and did not get it cleaned often enough. (pricy mistake) re asemble will be in a few weeks while i wait for parts i will give the rear caliper a refab kit with piston. and do some other maintanence ont the rest. |
de greaser and elbow grease make them shine right up
So, why are u respoking? Cause they're dirty?
Get a maid, gasoline and gloves and get to it will save you a lot of work... |
some of them where coroded badly under the grime. and some broke when taking the wheel apart for powder coat.
shipping the hubs rims and a few other bits off to powder coat tonight
going for shiny black rims the real question is stock vs green shiny hubs?? :D :D |
small update
got my hubs and rims back today and started on the front wheel and starting to look okay ish, later i discovered that i am missing 4 spokes and nipples for the rear. contacted my spoke dealer to see if he can make some extra. here is my front before i start to true it tomorrow at some point. https://cimg5.ibsrv.net/gimg/www.kaw...e1e4be3e0a.jpg |
Looks good. Take your time, keep it close on up/down run out, spoke tension should be uniform all around with minor differences - how do you check? ping! Work slow, turn in equal turns to start.
gonna go slow and go by ear with the ping method. (do not wanna fork out about 100$ for the torque wrench since expensive in denmark)
the plan is to have the wheel on the bike as i true it since i do not have a stand atm ps my first time doing it kinda interesting and kinda satisfying. |
Use a hose clamp and a piece of wire bent to touch the inside. Clamp it to the fork, not tight, but enough to not move. I've done the front wheel in the forks for my trials bike and the rear in the swing arm. Get a good wrench that fits the spokes. Ping a spoke on a good wheel and use that tone as a guide. It really isn't that hard to do it. When moving the wheel think and loosen over three to four spokes and do the three or four opposite to take care of radial run out. Once radial run out is good and all spokes are relatively evenly tight (ping) then do the side to side. To pull side to side you need to do 1-3 spokes pullling to the direction and 1-3 loosened to the other side. Only do a half turn or so when truing side to side. Middle spoke(s) are loosened/tightened a bit more than the ones to the outer part.
To me, the worst part is building the wheel, truing is kind of zen-like. |
ok first wheel is now true according to my zip tie and eye gauge.
now i wait for some parts again after an idiot drove over some of them in my garage (doing a small burnout) ps, i may take it apart again after thinking about anti corrosion might be an idea to apply |
