Does the KLX250 have a shared sump (wet clutch)?
Since folks don't like to talk oil on here much I've been doing some research over on
Bob Is The Oil Guy - Forums powered by UBB.threads™ Just to verify, our bikes do have a wet clutch right? |
Correct.
Originally Posted by wildcard
(Post 484008)
Correct.
Originally Posted by Brieninsac
(Post 484006)
Originally Posted by Lotrat
(Post 484052)
What did you learn so far? ...Other than that no one agrees.
(Post 484052)
It's amazing how much time you can spend reading about oil huh? What did you learn so far? ...Other than that no one agrees.
I use Motul 3000 20-50 mineral oil (US$10/L) since the first oil change. Bike has over 37,000km, and it hasn´t been even 2 years since I got it from the dealer. Which means I ride it a lot, every day, and between 6-7k rpm most of the time of my commute. I change oil every 5,000km. Bike still runs good as new.
IMO, the whole oil discussion is a waste of time, and a result of marketing hype and BS from people that know $h!7. |
Keep in mind the first number is the viscosity rating at low temperatures (0 degrees F IIRC) and the second number is the rating of the viscosity at operating temperature (200 degrees F usually). The W stands for winter.
So the only difference between 10w-40 and 15w-40 is that the second oil is going to be more viscous ("thicker" if you will) at 0 degrees than first oil. Both will be identical at operating temp. Unless you are planning to go riding in below freezing weather, i wouldn't waste any time in worrying about the winter rating of an oil. Just my .02 |
Does the "W" really stand for winter??? Never knew that, but I did know that the numbers did cover the low and high ends. Seems to me the W is redundant, or even useless, since some places may stay below 10 or 20 even in the summer (think Antarctica).
Originally Posted by Malves
(Post 484074)
