Do I need a new clutch, or am I missing something?
Old Mar 6, 2020 | 07:21 PM
mav91's Avatar
Default Do I need a new clutch, or am I missing something?
Hi All, New user here I've taken time to look around, but can't seem to find an answer.
My clutch on my 07 250s isn't slipping, but, I'm unhappy with where it engages and disengages. The lever and cable are properly adjusted. It has just a bit of free play, and I can move handlebars lock to lock without engaging the clutch. But, once I take up the free play, I only have to move the lever another centimeter or so, and the clutch disengages. To put it another way, my clutch is disengaging very rapidly at the very beginning of the lever movement. This causes me to accidentally slip clutch on harder trails and makes precise feathering of the clutch a little difficult. I would prefer for the clutch to start to disengage a little deeper into the levers travel, but I can't seem to find a way to adjust for that. My only other thinking was the clutch plates are worn to the point where it takes next to nothing to disengaging them (but arent worn enough to slip on their own). So. Am I missing something? Should I try a new clutch? Or is that just how these clutches are?
Thanks!
Old Mar 7, 2020 | 12:30 PM
dtrackermslazgromthailassi's Avatar
Thanks!
Mine is a rather long travel, however my clutch is quite worn for sure. Stock lever?
Old Mar 7, 2020 | 06:25 PM
mav91's Avatar
I have a shorty lever, but that shouldn’t change where it engages right?
Old Mar 8, 2020 | 03:27 AM
GBAUTO's Avatar
It will definitely affect the leverage you apply. That would make precise application more difficult.
Old Mar 9, 2020 | 02:25 AM
Yea especially if you're measuring the throw in "cm" and not degrees.
It's probably fine. the shorter it is the less travel you will have. and I guess the further it can turn too(degrees) depending on it's shape.
Old Mar 9, 2020 | 04:09 AM
durielk's Avatar
Running a shorty lever definitely is going to have a negative effect on feel. ... and IMO most 4strokers don't slip the clutch much, but maybe some do. I do hit the clutch at times, but don't really try and feather it much, just make sure your in the right gear.
Old Mar 19, 2020 | 04:00 AM
rfesu's Avatar
if you have to ride or feather the clutch, your gearing is totally incorrect for your riding application or style. that's a bit of a problem on the klx since it's geared for the street but built for the dirt. try different sprockets if you ride a lot off road, it'll help a lot... even dropping a tooth in the front usually keeps your clutch engaged like it's supposed to be.
other than that, you'll get used to it. when i started riding 100+hp bikes with race clutches it scared the living hell out of me, because between 0 and really fast, there was nothing. then i got used to it and realized that having a clutch like a toggle switch makes you ride like you're supposed to. same with having a throttle like a toggle switch. why are you at part throttle or at part clutch? that's no fun. stop going so slowly and it will stop being a problem.
piratelife
Mar 12, 2017 07:04 AM
RobG
Apr 18, 2014 04:46 AM
Ckahleer
May 14, 2012 08:03 PM
leisman7
Aug 16, 2009 03:48 PM
petlam
Sep 20, 2007 01:22 AM
