DJFields - I Need a Bit of Clarification
Old Oct 11, 2006 | 05:24 PM
Marty's Avatar
Default DJFields - I Need a Bit of Clarification
Don,
You made a comment:
"When the OE Head pipe has the flange mod done, it works great."
You've got me very interested now. What is the Flange MOD?
A link for imformation would be excellent.
I'm thinking of being the second person here with the HMF exhaust. Their support is now doubled!
Old Oct 12, 2006 | 03:43 PM
DJFields's Avatar
Default RE: DJFields - I Need a Bit of Clarification
Marty
The Exhaust Port Flange I.D. of the OE head pipe is welded from the inside. Depending on manufacturing variablity, the amount of weld can vary. This will cause a restriction in flow. Mine was fairly significant. Basically, I took a die grinder, removed it so it was nice and smooth, and had a skilled welder friend touch up the joint from the outside. You can't add a lot as the flange will not bolt back up properly, but as you should know, you don't need gobs of weld for a strong joint It's a very straight forward mod to let the exhaust gas flow freely. When you remove the head pipe to look inside you'll see when I'm reffering to instantly.
Hope this Helps.
Old Oct 12, 2006 | 05:57 PM
Marty's Avatar
Thanks for the replies y'all.
When I get a few minutes of spare time, I'll remove the head pipe and take a look.
Old Oct 12, 2006 | 06:59 PM
OMG you sound like an A-hole......lol J/K what's up fellas.
ORIGINAL: Iowaguy
Not to sound like an a-hole or nothing, but I wonder if all those people claiming the oem header pipe makes more power than a BigGun, Muzzy, or Fourstrokeworks header know this. LOL
Old Oct 12, 2006 | 07:07 PM
always coming around causing trouble hoedogg... we get into enough trouble with out your help.... lol
Old Oct 12, 2006 | 07:45 PM
s%@t disturber i am....[sm=icon_stickpoke.gif]....lol
Old Nov 9, 2006 | 05:15 AM
jellyfish's Avatar
I meant to say thanks for the clarification.
jeffjcalweb
Feb 17, 2014 03:36 AM
Mikeybb
Jun 4, 2012 01:55 AM
greenmachine
Jun 15, 2006 12:33 AM
Mr. Toad
Oct 25, 2005 05:22 PM
