Did I mess up?
Old 04-09-2006, 01:28 AM
djam101's Avatar
Default Did I mess up?
I did the air box and carb mods yesterday and I installed the clip in position no. 2 on the Needle, with the brass collar under that so it rests on the slide. Is that right? Or does it go on top of the clip?
There is a slight hesitation off idle when blipping the throttle but otherwise it seems ok. Im just not sure about that collar on the needle?
Old 04-09-2006, 01:44 AM
a16tony's Avatar
Default RE: Did I mess up?
Hey Joel, I don't have the KLX300 dyno kit, but on my KLR it goes on top of the clip. If your getting hesitation, move the clip down one space.
Old 04-09-2006, 02:49 PM
MaverickAus's Avatar
Nice pic Joel
Old 04-09-2006, 04:31 PM
incabiker's Avatar
Thats the pic from kawasakis web site
Old 04-09-2006, 04:38 PM
mrphone's Avatar
I just did mine yesterday, I put them in the following order:
Hope I did this right! I followed the directions from this forum as well as this PDF from Dynojet.
Old 04-09-2006, 04:42 PM
incabiker's Avatar
Yup, thats the way I put mine in, as shown above.
Old 04-09-2006, 05:26 PM
djam101's Avatar
Yea thats the pic from the an earlier post. Thats a REALY nice pic from you Ryan. Looks like I put that spacer on wrong. I'll be changing that ASAP! Its probably the equivelant of having the clip in the 4th or 5th position. Oh well live and learn. I just bought the needle, clip, spacer and #125 jet seperate, so I didnt have any instructions.
Thanks All !!
Old 04-09-2006, 05:32 PM
giacoman's Avatar
I wonder how important that brass collar is? I am doing the mod now and I don't recall even seeing it. I may have lost it, but I also wonder if it even had one to begin with.
Old 04-09-2006, 06:10 PM
bmwhd's Avatar
You need the collar and it goes on top of the clip. It's what holds the needle in the holder. Just the clip will work "sort of" but you won't get the desired results.
Old 04-09-2006, 06:32 PM
giacoman's Avatar
Thanks for the info. I wonder if I can get a brass collar that will work from auto zone or Lowe's.
Quick Reply: Did I mess up?
