D Tracker X Special.
I'm guessing an oil catch tank for the engine breather, by the way the hoses are running.
They are used when you put an air filter -usually K&N style- directly on the carb or EFI throttle body for increased performance. The filter has no fitting for the crankcase breather.
I did that with mine, but my catch tank is located where the air box used to be. It's just a tank that you run the crank case breather to once the air box is gone. That way the oil won't be going all over the ground if you take a spill.
Nope. From 2008 on, the name has changed from 'D-tracker' to 'D-tracker X'
That was just a custom modded bike for the Tokyo Auto Show.
The oil catch tank doesn't improve performance but it is a by-product of mounting an air filter or funnel directly to the carb or EFI throttle body, which does improve performance.
ninjakev
Oct 23, 2006 06:37 AM
sikanimator
Aug 9, 2006 11:17 AM
