Cylinder head work - cam bearing surfaces
Old Jun 6, 2014 | 11:52 PM
Broussard's Avatar
Default Cylinder head work - cam bearing surfaces
Is it possible to shave the cap and line bore the cam bearing surfaces? Anybody know a shop that will do it?
*sigh*
Attached Thumbnails Cylinder head work - cam bearing surfaces-img_20140606_194903_853.jpg
Old Jun 7, 2014 | 12:13 AM
Brewster's Avatar
It could cause cam to bucket clearance problems.
Ride on
Brewster
Old Jun 7, 2014 | 01:19 AM
Either the cams or the head would need to have metal built up on the surface and machined to size.
If the cam journals are machined larger the cam bearing surfaces would need be built up and machined/ground to a mating larger diameter. This could be done by a cam grinding company, no idea of cost.
The other method would be if metal can be added to the head journals and machined back to stock size. Not sure if this is economically feasible.
A guy in Bali
Feb 27, 2009 11:56 AM
ScoticusMaximus
Oct 9, 2008 06:10 AM
broady
Jul 1, 2008 01:13 AM
broady
Jun 15, 2008 07:30 PM
shox rox ice
Feb 8, 2008 12:33 PM
