Is this correct for stock exhaust?
Old May 13, 2008 | 04:06 AM
JETHRO980's Avatar
Default Is this correct for stock exhaust?
I recently put in a the 128 main, 40 Pilot, with N1TC eclip 2 from top. I have the firstbaffle plate drilled, kdx snorkle, backfire screen removed,notoil filter and a/f at 2 turns. I hadthe 125main/35 pilot setupand found thatI put the brass clip under the eclip and not above. (D$%# noob's!!) It runs good top end, but noticed a slight bogging from idle to 1/4 throttle.
Just wondering.
Thanks
Old May 13, 2008 | 05:01 AM
09KLXowner's Avatar
Banned
Default RE: Is this correct for stock exhaust?
my guess is you're too rich for the exhaust. those are mods done with a full system and even though you've drilled the stock exhaust, it didn't accomplish much.
also, what setup are you running now? you say you've "had" and then you "recently" are running whatever. What are you running as you type with low end problems? I'd say the 40 is too big. I used the stock 35 when I ran my BigGun full exhaust at 2.5 turns on a/f screw.
me thinks you're getting too much gas early and then it finally burns by the time the top end kicks in.
Old May 13, 2008 | 05:27 AM
oldphart's Avatar
Banned
same mods with an aftermarket slip on would be probably cool,loose the stock exhaust do the airbox mods, ya gotta new bike.
Old May 13, 2008 | 05:36 AM
oldphart's Avatar
Banned
gotta get rid of the stock exhuast, I know tis costly but somehow try and do it, wish I could help, but I got no spares, and don't start the which is better thing, tis what you can afford.
Old May 13, 2008 | 03:49 PM
big lou's Avatar
the stock one works for me 128 main 35 pilot i copyed this an it works only added a cross tube in side the mufler anit soundswith some bass to it not raspy .
[IMG]local://upfiles/8802/8F5EB1E84C324806855625E4E08731BC.jpg[/IMG]
Old May 13, 2008 | 06:26 PM
klx250s_rider's Avatar
Yep, way to rich for the stock exhaust - keep it as is and buy a HMF slip-on muffler for $240 - problem solved!
Old May 13, 2008 | 08:52 PM
djmerullo's Avatar
I like what biglou did...
Old May 13, 2008 | 10:18 PM
big lou's Avatar
updated the pic had to mod the muf.
[IMG]local://upfiles/8802/F8F96E8D568647499339C0304D015C81.jpg[/IMG]
Old May 14, 2008 | 02:43 AM
JETHRO980's Avatar
Man, and all this time I thought those jets were just for the free mods. CRAP! Last summer I put in the 125,35 and did the mods. I noticed a big difference but it still felt like it was lacking some where. Then I read a post last week with "put the brass ring above the needle" and I just knewIdid it wrong. So, I thought, "lower needle, less fuel - bigger jets!" And it seemed to get worse.I have found a nice lil place to trail ride so Ihave been playing with the gearing. Right now I am running 13/48 and its great.
Big Lou -I think I could manage to do what you did. Could youexplain a little of how you did it, and about the pipe you inserted?
Would drilling out the stock exhaust completely,help anything atall? (the wifeis cutting the bike funds)
Old May 14, 2008 | 10:51 AM
big lou's Avatar
pm me an i will set you up hard to write this all down.with your # ph
TUCAZ520
Aug 15, 2008 03:36 AM
crazy26
Aug 1, 2008 06:45 PM
Sid Post
Mar 30, 2008 12:53 AM
zzrotceh
ZZR 600
Mar 4, 2008 03:48 PM
hybrid
ZZR 600
Feb 13, 2008 03:40 PM
