Condenser
Old Dec 24, 2012 | 08:43 PM
MaximusPrime's Avatar
Default Condenser
My 650R has a condenser. It has a broken wire that I can't fix, it snapped where it goes into the condenser. What does a condenser do? Found one on fleabay for $30 or new for $60-80, which to buy? Can it go bad(other than broken wires)? Could this be why I don't get spark?
It would be an awesome Christmas present if that was the problem.
Old Dec 24, 2012 | 09:24 PM
darkmarc's Avatar
Yes, you need that for spark.
I'm not sure what mf rating that condensor is rated at, but, I bet any condensor from an autoparts store would work.should be cheaper than $10.00
marc
Old Dec 24, 2012 | 09:37 PM
Sweet! Thanks Marc, I'll hit NAPA before I order any parts.
At least now I know one problem. I hope that's the big one.
I hope that means the sweet roar of a big single will soon fill my house!
I need to know it runs before proceeding to order all the little bits it needs.
Old Dec 24, 2012 | 09:40 PM
klx4me's Avatar
A condenser increases contact breaker (points) life by reducing arcing across the contacts. It acts like a capacitor to absorb excess current.
Old Dec 24, 2012 | 10:27 PM
durielk's Avatar
Do we have points?
Old Dec 24, 2012 | 10:28 PM
Condenser...are we talking about a condenser like for a points ignition system or something else? How old is this bike? Just curious.
Old Dec 24, 2012 | 10:50 PM
It's a 93 KLX650R, the part diagram calls it that, I wouldn't have had a clue what it was or does. I have a very slim grasp on how ignition systems work.
Since there isn't a sub-forum for the 650 I thought all of your guys experience here would prove fruitful.
Old Dec 25, 2012 | 12:03 AM
Pine Barrens's Avatar
I had a 1983 Iron Head Sportster. It had points and a condenser. HD wanted $60.00. Chevy 250 6 cylinder points and condenser, about $20.00. Had the bike for 12 years, never had a problem. Just have to find something with similar ignition current capability/capacity (amps/volts/ohms).
Old Dec 25, 2012 | 12:34 AM
MP, I'm fairly positive that the '93 KLX650 has electronic ignition. I looked at the page on Bike Bandit that had the ignition system and didn't see a condenser. What section on the parts diagram are you seeing the condenser?
Old Dec 25, 2012 | 01:10 PM
It was in the generator section. Part #21013 in the drawing.
I have had 2 answers about it running without it. One yes and one no.
I'm pretty sure it does have electronic ignition because it has the "black box". I guess I should have left out the ignition system comment, it's just where I expect my problem is, since I don't have spark. The PO said it ran until he crashed, then he couldn't start it afterwards. That led me to look for simple things, like busted wires. Guess I need a real service manual for all the test procedures on the electrical crap.
Was hoping to get lucky and find an easy electrical problem as to why I can't get spark.
I guess I'll go back to parts drawings and sit by the bike and ID parts and inspect them.
Someone hacked the wiring harness to add a light using speaker wire.
Looking at fleabay I found a wiring harness and condenser, and am looking for a pulse coil (source of spark, yes/no?).
