CO2 inflator
Old Oct 13, 2017 | 11:15 AM
s10gto's Avatar
As long as the c02 has a good seal to the stem it will over power the valve core. For instance you can take a plain air chuck then jam it onto a stem you will get a tire to fill @ only 90psi in the hose. Done this many times when the adapter has gone missing.
C02 cartridges are way over 90psi. @ about 77*F they are around 850psi.
Old Oct 13, 2017 | 11:34 PM
NEWPARTSRULE's Avatar
Cool
Cool. So his assumption was correct.
Old Oct 14, 2017 | 08:26 AM
Finecitygirl's Avatar
I'm following this thread too...about to buy an inflator tool and want to be sure I get one that actually works!
Old Oct 15, 2017 | 01:20 AM
Werloc's Avatar
This is one of the best out there. All metal, no cheap plastic parts, easy basic inflater. Can’t go wrong with this one.
Amazon Amazon
Old Oct 15, 2017 | 04:14 AM
durielk's Avatar
That inflator looks good, note that it only uses threaded cartridges which are pricey compared to non-threaded. On the moto for em use, this is not so much of an issue. I bicycle a lot and have quite a number of flats, so all mine have non-threaded or threaded rating and I use non-threaded CO2 almost exclusively.
Old Oct 15, 2017 | 06:39 AM
Werloc's Avatar
I’m just sayin. Spend a little more $ or chance walking when you go flat. Try using slime if you can on the pedal bikes. Once I did, never got flats. Basicly, you get what you pay for. There’s other good reliable non threaded inflaters out there. Maybe its just me, but high pressure and plastic don’t mix well IMO. My post was answering Finecitygirl’s comment.
Old Oct 15, 2017 | 07:26 AM
Cheers Werloc, I ordered the Sealey one yesterday. They're motorcycle specific, so ought to do the job fine. It comes in a little case, so I can put patches, glue and other puncture fixing stuff in there too! Hopefully, once I get my new tyres, I won't need to use this kit??
Old Oct 15, 2017 | 12:56 PM
Werloc's Avatar
LOL, Yes, we spend money on something we hope we never use..... Funny, but very true....LOL
Old Oct 15, 2017 | 01:05 PM
Werloc's Avatar
Don’t know what your payin for cartridges, but $1 each is to much? Not worth a buck to save your day?
Cyclingdeal Threaded CO2 Cartridges Refills for Bike Bicycle Pump Inflator, 30 x 16g
Amazon Amazon
Old Oct 16, 2017 | 12:38 AM
durielk's Avatar
How many of those 16g's does it take to put 15psi in your tires?
