Clutch Lever?
Old 08-15-2009, 11:37 AM
leisman7's Avatar
Default Clutch Lever?
Is their anyway i can loosen my clutch levers resistance? I was on a kx450 the other day( killer bike) the bikes clutch lever took barely any pressure to pull it in.
Old 08-15-2009, 12:01 PM
neilaction's Avatar
I'm assuming everything is clean and lubed?
If it is then making the clutch action lighter requires a bit of work.
Old 08-15-2009, 12:03 PM
leisman7's Avatar
Everthing is clean and lubed
what do i got to do?
Old 08-15-2009, 12:31 PM
neilaction's Avatar
You could try pushing the perch in towards the centre of the bars so you get more leverage.
Have a search around and see if there is a Magura Hydraulic Clutch kit that will fit.
Or maybe look for a different perch/lever set up.
I can't imagine its worth the bother.
I find the KLX clutch action pretty good.
Old 08-15-2009, 12:41 PM
leisman7's Avatar
After sitting on that kx450 and feeling the effortless of the clutch play it got me jealouse man.
Old 08-16-2009, 03:03 AM
MaverickAus's Avatar
Either there is something wrong with yours or it's in your head.
Old 08-16-2009, 04:40 AM
klx250scott's Avatar
This is a joke right? Really? You guys kill me!!
Old 08-16-2009, 12:25 PM
Klxrelic's Avatar
I find mine real easy. I'm after cutting a couple inches off. Can still operate clutch with two fingers no problems. Dont want a real easy clutch anyhow. think that would be too strange- no feel maybe.
Old 08-16-2009, 01:18 PM
leisman7's Avatar
It might be in my head man, but **** that kx450's lever pull was smooth
Old 08-16-2009, 01:25 PM
skubidoobie's Avatar
My KLX has the lightest clutch pull I've ever felt, first time I got on it I checked to see if the cable was connected lol.
Quick Reply: Clutch Lever?
