Clutch issue? Could use some advice please!
Old Jan 11, 2012 | 05:27 AM
joblesstobias's Avatar
Default Clutch issue? Could use some advice please!
Ive browsed the forums but I finally had an issue.
I just fixed a flat front tire on my klx 250s when i realized my clutch play was all messed up. I fixed that but now whenever I hold the clutch in it seems like the gears don't disengage all the way. When I push the bike it is much harder to do so in gear with the clutch in than when I am in neutral. I feel like this isn't good but perhaps I just never noticed? I could use some advice!
Old Jan 11, 2012 | 01:23 PM
CousinLarry's Avatar
It sounds like the clutch isn't traveling as far as it should be. Visually watch the arm above the clutch cover to verify that it's fully dis-engaging when you pull the lever.
Old Jan 11, 2012 | 04:17 PM
I got some vice grips and pulled the clutch farther over but that doesn't seem to help. Like I said I can push it with the clutch in but there is noticeable resistance all through the spin if its not in neutral.
Old Jan 12, 2012 | 02:30 AM
whyzee's Avatar
re-adjust your clutch cable.....properly.
colby_nealy
Jan 15, 2014 05:10 PM
Ian P
Aug 21, 2008 02:21 AM
kx slaughter king
KDX200
Dec 9, 2007 10:00 PM
Canam Harry
Jan 26, 2007 08:04 AM
