Clarke tank fit and finish??
Just wanted to add one more data point to this thread for those considering the Clarke tank. I received mine (clear) last weekend and installed it yesterday and went riding...
- Fit and finish are overall excellent!
- Main fuel tap does indeed sit very close to a frame cross member, but the tank shouldn't move. I'll keep my eye on it, I'm comfortable it's good as is.
- Regarding the brass fuel taps that you remove from the stock tank and screw into the fittings on the Clarke tank: I found the smaller stock o-rings that nest into the grooves of both male and female gave a better seal than the larger o-rings that Clarke provides that don't nest. No leaks with the stock o-rings, and they fit perfectly.
- Regarding the flange on the radiator shrouds that no longer fits under the seat, I trimmed mine off thereby showing a bit more of the tank which I consider my "fuel gauge". I plan to put some Sharpie marks at the varioius fuel levels so I can better manage fuel when out exploring in the sticks.
- As others have mentioned the fuel cap already has a valve it so a simple piece of hose that dumps somewhere on the front side of the handlebars works just fine. Should Clarke provide a piece of tube just in the interest of completeness? Probably, no biggie though.
I've spent too much on my Yamaha's restoration so show me some pics of this Clark tank so I can decide whether or not to buy it instead of Warp9 Rims and spoke kits for the Yamaha!
Worlok14
Sep 10, 2008 03:12 AM
