Chirping sound from down below
Old 09-01-2008, 06:58 PM
redpillar's Avatar
Default Chirping sound from down below
So I am riding home from work and I hear my pager go off. I pull over and look at the pager. Nothing. I flash up the bike and carry on home. As I get to about 40 kph (about 20 mph) my pager goes off again. I pull over, check the pager and still nothing. I continue on my way and the same thing happens. A chirping sound from what I think is the right side down below or rear wheel area. As soon as I get below 40 k or so the sound goes away. It gets faster as I increase speed, does NOT go away when I pull in the clutch and let the motor idle as I coast along. It does not go away when I slightly touch the rear brake. It starts after I have been riding for fifteen minutes or so. The sound is like what happens on a car when the brake pads need changing and the warning chirps start. I oiled and tightened the chain. No difference. I am starting to think rear wheel bearing. Fuel tank venting? WTF??Anyone got any ideas? Thanks
Old 09-02-2008, 12:12 AM
2k1w=no$'s Avatar
I am assuming that the rear pads are ok?
Maybe swingarm bearings need grease? Without hearing it I am of not much use.
Old 09-02-2008, 12:34 AM
RaceGass's Avatar
This worked for me, the speedo cable/wheel spacer at the axle was making a funny noise. So I squirted some WD40 on it around the spacer and the noise went away....
At low speeds it didn't make any noise only when going above 20 mph.
Old 09-02-2008, 12:55 AM
redpillar's Avatar
The pads are good, brand new, I will try the speedo cable this evening sounds like you might be on to something. I hope you are right!
Old 09-02-2008, 12:58 AM
redpillar's Avatar
The noise is most noticeable when I am on pavement and no real movement to the swingarm, but I will see about that as well. Thanks.
The sound is a high pitched chirping, almost a metallic scraping noise.
Old 09-02-2008, 02:25 AM
redpillar's Avatar
The WD 40 did the trick! Thanks, it is really hard to tell where a sound is coming from. I owe you a brew!
Old 09-02-2008, 02:40 AM
RaceGass's Avatar
KF forum to the rescue! I have to say thanks to others that have helped me the same way
Old 09-02-2008, 02:47 AM
WestOzKLX's Avatar
Job done. Beers all round you say? LOL
Old 09-02-2008, 02:58 AM
redpillar's Avatar
Sure come on over!! We can go for a ride!!
ScoticusMaximus's Avatar
Awesome, im glad you solved this, i am going to go home tonight and do the same because mine started making a very similar noise this morning.
thanks,
scott.
Quick Reply: Chirping sound from down below
