Checked my tire pressure today...
Old Apr 23, 2012 | 09:22 AM
My buddies bike....
Old Apr 23, 2012 | 09:42 AM
Borg's Avatar
It appears to have some sort of Orange stuff on it!
Old Apr 23, 2012 | 03:01 PM
Originally Posted by dan888
Deej, do you get into any tight, fast, single track with lots of roots, and rocks? If you do, you should get rim locks and run low pressure, you will never go back. Trust me
20 + psi might be fine for what you ride, really it all depends on how aggressive you are, and what type of terrain you are riding.
Dan
I leave it at 20+ in all the conditions I ride, blacktop, gravel roads and trails. Its all good!
Old Apr 23, 2012 | 08:22 PM
Borg's Avatar
Well I'm riding an SF, so the tires should be kept up to pressure.
Oil? Some oily one..
Old Apr 23, 2012 | 08:23 PM
ahnh666's Avatar
after this post, checked my tire pressure (last time i check was about 5,000 miles ago)...surprisingly, perfect pressure....29 psi front and 33 psi rear....
Old Apr 23, 2012 | 08:41 PM
Highbeam's Avatar
I race this thing off-road, there is nothing wrong with 20 psi in a knobby. Yes, you'll get better traction at 12 but you will also be the guy failing to finish the race because you got a flat.
20 psi all the time, UHD tubes, rimlocks, and slime in both tires. Since I started equipping bikes like this several years ago I have never gotten a flat.
Old Apr 23, 2012 | 09:52 PM
Ok. But my experience and that of every racer I know, even professionals, says otherwise.
Good luck!
Old Apr 23, 2012 | 10:02 PM
  #28
zomby woof's Avatar
I run 15 in my race bikes, and they're 100 lbs lighter than the KLX. I also see no problem with 20 psi. I will experiment with different pressures now that I have the rim locks, but so far, 20 psi seems to have worked the best.
Old Apr 24, 2012 | 01:57 AM
  #29
redpillar's Avatar
Default Idrider
I send my tires to IDRIDER to have the pressure checked.
Old Apr 25, 2012 | 10:42 PM
  #30
Get the name right...there's no "E" in IDRIDR
And don't call me Steve.
redpillar - your tires had zero air pressure. They're now filled to 22.4 front and 25.7 rear psi. Let me know when you're ready and I'll send them back.
