chain and sprockets
Old May 25, 2009 | 09:56 AM
fgk228's Avatar
Default chain and sprockets
hey guys,
im up for a new chain and sprockets
long to spend around the $200aud for everything(i will install)
what brand etc have worked, i have heard about the harded style lasting around 60 000 - 100 000 ks, as i am a cheapy i would like them to last a long time.
i am planing to run 14-46 sprockets, thoughts on this, im running 14-49 and would like some more road friendly gearing.
thanks in advance
Old May 25, 2009 | 12:21 PM
punkenduro09's Avatar
im all ears for this, im about do also.
Old May 25, 2009 | 12:24 PM
lcpl0331's Avatar
Renthal sprockets and DID chain. I run the 14/46.
Old May 25, 2009 | 03:12 PM
Sid Post's Avatar
I used a 108 link D.I.D. premium chain (~$100) and a 46 tooth JT Sprocket rear (~$35).
14/46 gearing works well. I run about 500RPM more in top gear for any given road speed (at least in the mid-range ) and have more power for sand and hard starts off road.
Buy a 13 and 15 tooth front and you can run stock ratios to really low offroad gearing.
Old May 25, 2009 | 03:40 PM
WestOzKLX's Avatar
Renthal R3 'O' ring chain and Renthal Ultralite rear sprocket with a JT steel front. 13/45 gearing, 108 links in the chain.
Old May 26, 2009 | 06:03 AM
fgk228's Avatar
whent dow to my local bike store, came up with this
jt harded steel sprockets
rk chain
all up 180aud
thoughts
and for every one who is running 14/46, at 80kph what rpm do are you at
Old May 26, 2009 | 06:14 AM
MaverickAus's Avatar
chaingang sprockets will last forever and he has chains too
http://www.chaingang.com.au/shop/ind...ewDoc&docId=24
Old May 26, 2009 | 06:50 AM
fgk228's Avatar
would love to go for the chain gang but the sprockets are way to expensive, really good, but out of the budget.
Old May 29, 2009 | 06:14 AM
fgk228's Avatar
well i ended up going with this from www.ballards.cc.
14-46 combo, using supersprox
DID chain
all up it came to 189aud, posted
Old Jun 22, 2011 | 05:21 PM
jhoffy22's Avatar
If you guys had to say,
Best combo for strictly offroad:?
Best combo for strictly on road:?
Best combo for mixture of both:?
Best for mostly on road with a little bit of off road:?
Basically I want to know what to run if I want the bike to be as quick as possible out of the hole and then what to run if I want good top end speed. I have a 351 kit on the way so keep that in mind.
Bob Billen
Feb 12, 2023 10:26 PM
csaba1589
Mar 29, 2010 02:18 AM
cliffsta
Dec 23, 2008 12:31 AM
95zx6rGuy
Sep 7, 2007 03:27 PM
95zx6rGuy
