Chain Lube
Old Jun 10, 2007 | 05:27 AM
Default Chain Lube
This topic comes up from time to time and in the past I've always used 90W gear oil - two or three drops per link. Works fine, however, I think I've found something better:
The consistency is similar to water, actually, maybe a little thinner. I still use just 3 drops per link - one on each o-ring and one on the roller. The liquid mostly evaporates leaving the teflon lubicant behind. The advantage over oil seems to be that your chain ultimately stays cleaner and should wear better since oil attracts dirt and grit, but since this goes on pretty much dry, it doesn't suffer from that. Also, there's no oil sling which easy to do if you put on too much oil.
It's made for bicycle chains, so check your local bike shop. It's pricey, but using just a few drops per link it lasts a long time.
Old Jun 10, 2007 | 11:57 AM
poodlenuts's Avatar
Default RE: Chain Lube
That stuff works great, Thats what I used on my mini's[8D]
Old Jun 10, 2007 | 12:36 PM
cwgoff's Avatar
That looks like a great product. I've been thinking about making a change. I'll give that a try.
Thanks.
Old Jun 10, 2007 | 12:43 PM
cwgoff's Avatar
As I was poking around to see what Brian meant by "pricey" I found the site for the manufacturer. It looks like there are a couple of other interesting options from the same company. I am particularly intrigued by the ceramically reinforced one. It is probably just a marketing ploy, but if there is anything to it, it's pretty cool.
Here's a link.
Old Jun 10, 2007 | 12:56 PM
poodlenuts's Avatar
I think the coolest thing about it is that its not as messy as spray lubes[8D]
Old Jun 10, 2007 | 12:59 PM
boxermachine's Avatar
I've been using wd40- I spray and wipe. What is the advantage of the dry lube?
Old Jun 10, 2007 | 01:00 PM
FM_Thumper's Avatar
Is it okay to use bicycle stuff on dirtbikes? The shearing force generated by the sprocket on the chain is mega-times greater on a dirtbike than on a bicycle.
Old Jun 10, 2007 | 01:42 PM
LearjetMinako's Avatar
Just about anything made for motorcycle chain lubes are pretty much costly. I use Royal Purple Max-Chain for mine. About $12-18 a can vs $2-4 for WD-40. But it does what it says. It goes on liquid spray, and then evporates, leaving a wax residue behind to protect the chain. Doesn't really sling off, easy to apply, put still some mess to clean if over-sprayed.
Old Jun 10, 2007 | 03:58 PM
dmar's Avatar
I use the bel ray no sling lube. It goes on clean and is white in color, no sling what so ever. It is made for regular or oring chains. Superior to any other chain lube i've ever seen.
Old Jun 10, 2007 | 06:29 PM
ZX1100F1's Avatar
I had been using Tri-Flow, it slings off like crazy, great stuff.
I think I'm going to try some of this Finish line dry lube, made for a bicycle but should work well for a motorbike too.
